Need pics of TTi setup
Old Mar 23, 2004 | 02:41 PM
ChevyThunder17's Avatar
Default Need pics of TTi setup
Hi guys! Need some help... I need to see any undercar shots of the plumbing for the TTi kit. I picked up a 3" cat, but I want to know what the plumbing looks like. I should be able to get it installed pretty quickly, already relocated the alternator, doing the fuel pump & injectors this weekend. I just need a base Edit to start with... I have my Wideband o2 as well.
What is the deal with changing out the valvesprings? I see guys are doing that on their motors. Is it really necessary? How much would it cost to have it done?
Old Mar 23, 2004 | 02:57 PM
MIGHTYMOUSE's Avatar
did you look at the instructions?http://www.turbotechnologyinc.com/ls1_instructions.htm
the cat connects to the downpipe and before the -to cat back pipe
intake pressure (and more importantly exhaust pressure) will try to hold the valves open, to fight that you have to increase the spring pressure. stock springs can still survive around 6psi boost at normal rev's.
Old Mar 23, 2004 | 03:05 PM
I have the instructions that I got from that page, I was just looking for a really good large pic from the downpipe back. I want to make sure that I have all the pipes I will need. Downpipe to cat to ? to SLP 3"Catback. What is at the ? mark... I don't rev over 6K... Would 6 lbs be good on a stock motor? I have my 42's and whatnot, like I said I just need a edit file for it...
Old Mar 24, 2004 | 06:13 AM
smokinHawk's Avatar
i have some pics of it on my site
http://www.cofba.org/users/smokinhawk/TurboBeast-pics/
