engine knock- first time i ran to 6k with the turbo
nobody said get it DYNOtuned.. they just said get it TUNED... and the guy who said it be a bomb was referring to hot plugs and removing the knock sensor, and nothing about a tune... if your going to try and give some advice **use facts.
#33
The point is these 5.3's have proven to hold up pretty well. I have over 1500 miles on mine. Just changed the oil a second time and no signs of bearing wear. My entire running engine was $583 complete with wiring harness, pcm, alternator, starter, etc.. I used all of it.
College is expensive. This actually may be the cheapest way to go in the long run. If you blow it up, you can get another one and still sale the alternator, starter, harness, pcm and probably get most the money back. You would just be out of the labor time to do the swap.
Good luck. Hope this helps a little.
#34
From what Ive read, you can easily put 15 psi on a 5.3 and it will smile all day. That is of course with proper fuel and minimum supporting modes.
Im a college student, so a 5.3 is what ill play with for now. Looking to put around 20 psi on the little motor with the new magnum MT80.
This is a great thread shows what a completely stock 5.3 can do.
https://ls1tech.com/forums/forced-in...highlight=gt45
#35
cool, good information here.. from what im reading the lt1 4l60 wont bolt up... i have a mess of money in my trans and that would be a big waste if there was not way to make that work... but also is there a way to get ac? this would not be my dd but it would still be nice to have ac..
#36
FWIW I just built my first 5.3 with turbos. I daily drive my 69 Chevelle and put a running 5.3 with 64k in miles in it. I used my TH400 and old convertor. Sitll was able to almost use everything I had and almost everything that came with the new engine. I paid to have it tuned on the dyno like was mentioned. Then I could start playing with the tune on the street. It was tuned to hold together at WOT but runs a little rough on the street. lol I rape it on a daily basis at 15lbs of boost. I took it to the track for the first time last week and left off no boost and ran it to only 7lbs of boost and it ran 6.85 in the 1/8th. Then took her home.
thanks for the info! do you know how much power you car makes at 15lbs? also are you running the stock heads?
#38
Yea, but I was just messing with you.
Sounds like you had a knock issue due to too much timing. If your car wasn't tuned for the added airflow from the turbo then the over timed issue becomes a really big problem because now your over timed and lean.
That combined with the hotter plugs you were running spelled disaster for you. My guess is the tops of at least one if not several of your pistons are gone along with the 1st ring land if not more. Most likely when the piston and ring land went it butted and bent the rod also taking out the bearing which is why it is knocking now.
#39
Right around 600 to the wheels but we only ran it to 6k because only one pump was working. Realistically it is probably around 635-650rwhp. Nothing great but I drive it a lot.
#40
