6.0 block power limits
Let me know if you need some more questions answered about our ERL Superdeck 1 6 bolt or our 4 bolt stuff.
370ci is too small, too much boost needed = lifting heads.
The shop will take hundreds of pics and they'll post them up.
If you are on a budget think about the above setup with some decent forged rods/pistons. Thermal barrier coatings are worth IMO the extra insurance. With a good tune it should be good for 1000rwhp on a basic setup.
That seems to be the barrier when you really hear the whooshing sound.... meaning the dollars flying out of your wallet for reliability
i would stick with the iron 6.0l and half fill it at least. the dm girdle would help on even an iron block, i bet, but you got to buy longer main studs with it. the key is to strengthen the mains so you can clamp the heads down tighter without distorting the bottom end. and a spot on tune! good luck with your build!
ERL: Sent you a PM.
