what pistons?? Wiseco? Mahle? Diamond?
LS1Tech Sponsor
You should contact Kyle at Thompson Motorsports. He now runs Diamond Pistons in his short blocks and can get you set up with the exact combo you need to get your desired compression ratio! Tell him Jon sent you!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
We have a huge selection of Diamond in stock and a pretty good selection of Wiseco and probe as well. They are all great pistons when you get to this level of piston. I think you will be very happy with any of the above, I would make the decision based on the use and piston available (+/-CC for the use with ring lands set where needed for your use).
