9 Sec pump gas w/meth Stock 6.0 mustang
I'll be maxing out my little mpt70. Somewhere around 600rwhp I hope. I just got off the phone with AIS and I am going to be fine with my set up. I'm going to calculate my total meth flow and adjust my AFR target from there.
very cool! i bet that thing is a blast on the street.
__________________
YOUR SOURCE FOR ALL THINGS TURBO!
CASEY@HURONSPEED.COM
Check us out on Facebook at: www.facebook.com/HuronSpeed
TWITTER @HURONSPEED
TWITTER @HURONSPEED
I suggest tuning it on 91 first on conservative timing get your af at 11.8.then bring your Meth in and timing.that way your not crunching a lean gas tune with your methonal.
Sounds like a plan. Thanks for the tips. I am just learning this fuel injection stuff. My previous setup was a blow through carb deal. Did you ever get the 600rwhp car to the track? Curious to see how well it ran. Cheers, Carl.
Nope it was a small rod motor making 600 threw a t400 and broke a rod on the street lol.but it was a 3000lbs fox it was a solid low 10 hi 9 car on pump
Also dont put a nozzle b4 the turbo. You could damage the wheel. Put them b4 the throttle body. You have to remember that the meth is flamable and is mixed with air. The are between the valve and the fuel source is a compression chaimber and one back fire could turn it into a bomb. Just something to think about.
#33
To each his own. I run strait meth. Water is pointless imo. Ill take the octane and cooling properties.
And m2w thanks. Its only gona get faster. Piting miss piggy on a diet and adding some more power.
