do i need a bigger wastegate or different boost controller?
Old Mar 27, 2012 | 11:20 AM
My2kz28's Avatar
Default do i need a bigger wastegate or different boost controller?
Ive got an older silver faced turbosmart eboost controller and the speed shop i have been taking it too that is very reputable (RMCR) has the boost controller set to no more then 12 psi. Soo I drive it for a week and it never gets over 12 psi, then today i hit a 4th gear highway pull and see 16 psi!!! Not good for my forged lt1 but i cant for the life of me find an owners manual for one of these! whats causing this to happen? I cant get over 10 psi in second with my current sucky gears so im stumped..I just dont want to start tinkering with the up and down button before talking to people on here. We all know how easy it is to pop a motor now days
Old Mar 27, 2012 | 03:46 PM
My2kz28's Avatar
I have the tial 38 mm wastegate...could that be the reason is it too small???
Old Mar 27, 2012 | 05:35 PM
My2kz28's Avatar
i turned it on wastegate only and it is still spiking way up to 14 or 15 psi...does this confirm that the wastegate is too small?
Old Mar 28, 2012 | 08:06 AM
MIGHTYMOUSE's Avatar
what does the shop say? tough ****?
eb1's instructions:
http://www.yariksteel.ru/manual/Skyl...OOST-40-60.pdf
Old Mar 28, 2012 | 10:00 AM
My2kz28's Avatar
I took it back to them and they adjusted it, lowered the over boost, and it stayed at 12 for a while but now shes creepin up to 14-16 again but only in 4th and 5th..said it could be the wastegate but wanted to troubleshoot what else it could be before getting into changing the wastegate tubing. They are busy as hell over there so thought id get some more opinions on here..was also hoping someone would provide what you just did mightymouse!
Old Mar 28, 2012 | 12:42 PM
MaxxMitchell's Avatar
Wastegate is too small, either add a second 38mm or 44,46,50 mm in place of current 38mm.
Old Mar 28, 2012 | 01:24 PM
is the gate vented to atmosphere? if not can you?
also what is the exhaust system after the turbo? can you close it up (e-cutout) and try again?
if either of those things affect your boost, then your gate is either not operating well (sticking) or undersized.
turbosmart has a couple different plumbing options for the solenoid, i believe one is specific to helping with creep.
i have a 42mm gate and with the exhaust capped up it can hold 11psi boost with the gate external but with the exhaust dumped/opened minimum boost goes to 13. thats with a 10lb spring.
Old Mar 28, 2012 | 02:13 PM
My2kz28's Avatar
The gate routes into the downpipe and is actually a slip in type pipe there so i guess it can be removed. Downpipe/exhaust is a 3 inch mandrel no cats to a borla catback with no plate in there. So your saying if i but the plate in the borla i can drop boost a little maybe?
Old Mar 28, 2012 | 02:24 PM
yes the backpressure in the exhaust cancels the boost pressure relative to the pressure ratio.
Old Mar 28, 2012 | 04:02 PM
stevieturbo's Avatar
Apply a little logic.
It was running fine ( albeit only for a week ). Now it isnt. So clearly the w/g hasnt suddenly got too small if it was fine for a week.
Check all hoses to ensure none are loose or leaking.. Check the boost control solenoid is working and not clogged with oil or something
Also, turn the boost controlled off and try it. You should get w/g pressure only whatever spring is in there.
Old Mar 28, 2012 | 04:36 PM
My2kz28's Avatar
Ok cool thanks Mighty i will throw that plate in until i get a different wastegate
Old Mar 29, 2012 | 09:37 AM
slow67's Avatar
Gingervitis Addict
Is there a a flex bellows before the wastegate?
Old Mar 30, 2012 | 04:16 PM
My2kz28's Avatar
theres a flex plate in the crossover
Old May 1, 2012 | 07:34 PM
Marty Staggs's Avatar
Yes.
If boost continues to climb in upper RPM's in 4th and 5th gear, the gate is not flowing enough to control the turbo speed = boost.
Old May 1, 2012 | 08:01 PM
Brad Campbell's Avatar
Originally Posted by Marty Staggs
Yes.
I think that was sound advice though from Stevie. All other things being equal; if the setup was working fine before and now it's not. Perhaps you can just throw a small spring in there and run it right off the gate. If it over runs the spring and goes back to 16psi that's your answer.
Old May 1, 2012 | 08:03 PM
qqwqeqwrqwqtq's Avatar
Scan the car and check the IAT's in the higher gears. If IAT is climbing very high and the PCM is pulling a bunch of timing, you will get boost creep with very low ignition timing.
