How are they not pushing water??
Old Mar 30, 2012 | 12:48 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Originally Posted by 831jd
Its all about the tune then huh?
I think not only tune, but cylinder temperature has a lot to do with it as well. Notice the guys pushing these stock shortblocks are running e85 or water/meoh in some combination.
Old Mar 30, 2012 | 04:22 PM
chub406's Avatar
wow! thats crazy. thank you for the info. this will be my second car. my first one took me 6 years. drove it 4 times and it got stolen and never found. so now i have an 85 gn. 10 point and a 9 inch. it weighed around 3050 with a big block. wanting to be comfertable in the 9's with boost up. Is it the same with the lq motors? I would think even a 76mm with that high of boost would be more than plenty. You have to run an SD tune to be able to run that much boost though right?
Old Mar 30, 2012 | 04:42 PM
91sonomast's Avatar
Originally Posted by The Alchemist
It's when the cylinder pressure gets so high, that the mating surface between the cylinder head to the head gasket to the deck of the block seperates, allowing water to push past.
Ah gotcha, so the heads are lifting. Thanks guys.
Old Mar 30, 2012 | 07:09 PM
chub406's Avatar
im in iowa so e85 is easy to come by. Its also getting an intercooler. what are you running for a fuel system maxx?
Old Mar 30, 2012 | 07:16 PM
bad6as's Avatar
I put 25psi to my ls9 gaskets, still good
Old Mar 30, 2012 | 07:38 PM
chub406's Avatar
wow. thats crazy to think. what are you guys running for a fuel system to support that? what kind of tune are you running?
Old Mar 30, 2012 | 09:20 PM
I8UR4RD's Avatar
pushing water is exactly what I did on my motor. That liquid went into the cylinder wall....and well if you have ever seen what happens when you throw boiling water on a frozen windshield then you surely get the idea. That was my fault for having too much timing, as well as making 2lbs more boost than anticipated, and the cam I had really was far more beneficial at making the thing boost midrange than we had anticipated....made 600rwhp on the dot through the auto before we lost compression at 5800 rpms. was going to send it to 6500 lololol. live and learn.
Old Mar 31, 2012 | 09:23 AM
bad6as's Avatar
Comes down to cyl psi. Fuel and good block/head surface.
Old Mar 31, 2012 | 10:42 AM
02anti_vnm's Avatar
I constantly was pushing water on my old setup ls6 block afr 225s ls9 gaskets arp head studs pt76gts 18psi and pump gas/methanol and had an awesome tune on it. I'm thinking it had a lot to do with the aluminum so the new setup is iron block with 1/2 head studs well see how it goes
Old Mar 31, 2012 | 12:38 PM
Slowhawk's Avatar
LS1Tech Sponsor
Alot of people lift the heads and don't know it. Most race cars measure how much is pushed and when it hit's a certain limit they change gaskets. It's a norm in racing.
You can hit a high boost/power on a dyno. It's ussually the high speed run on the street/track that lifts the head.
Old Mar 31, 2012 | 04:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I think that folks are better about tuning and AF now compared to the old days.
I don't think about it in terms of boost, but more in terms of ET and weight. In the very beginning of the FI LSX scene, folks would lose head gaskets only running in the 9's, then it was the low 9's.... By say 2005, 7 years into the scene the bar was the low 8's. Most folks running low 8's in the 1/4 would inevitably push water.
Now that we have all this 6 bolt stuff the bar is really high 7's for high hp builds. The guys running mid 7's and quicker have some pretty trick blocks.
But if you are 4 bolt, stock size head studs, and say heavy, yeah you have to watch out. Heavy = Load = Heat = problems. Iron won't distort as much with heat so the aluminum stuff will have deck problems as well as bored distortion before aluminum will.
Maybe Kurt will chime in.
Old Mar 31, 2012 | 08:55 PM
  #32
SnIpEz's Avatar
That threw me off for a second lol, now I see the typo.
Old Mar 31, 2012 | 10:10 PM
  #33
MaxxMitchell's Avatar
Was stock 3/8 line, brfpr, 2 255s, bap, 83lbers, stock rails. Just leaned on it and got ballsy
Old Mar 31, 2012 | 11:39 PM
  #34
chub406's Avatar
wow. that is extremely ballsy with e85 aint it? i was figuring -10 up and -8 return. i could do an in tank setup but prob go with a cell. are you running a stock computer? Thats why I want to go with iron block. My buddy has a 4.8l in a truck I could build but holding out for the 6.0l. The 6 bolt blocks are just the lsx right?
Old Apr 1, 2012 | 12:47 AM
  #35
Outlaw666's Avatar
good info in here
Old Apr 1, 2012 | 03:51 AM
  #36
ittwgn's Avatar
hi i run an lq9 iron 408 stock 241 heads, cometic gaskets, have seen 20.4psi with c16 no issues yet!!!! as said earlier isn,t the mix of iron block, aluminum heads a better way to go to prevent this???? along with tune arp bolts/studs good fuel etc going bigger turbo and some afr or t/flow heads so might replace the arp bolts with some studs just to be safe!!!! cheers
