Got My STS Turbo Kit Today
Old Mar 24, 2004 | 08:36 PM
YOUR03COBRA8ME's Avatar
Talking Got My STS Turbo Kit Today
Finally I got my kit Looks great! I got it with the 60-1 T04E .81Back housing, P-Trim My car is in for some warrenty work (Tranny Went)I get it back monday , so tuesday the kit will be installed then Friday to the track on 3 psi stock fuel system untuned then the following week the car will have new fuel system 42# inj ,255 Walbro Dyno Tuned 5 psi and 8 psi on the methanol Anyone near corol springs area who wants to see the kit PM me and i give you a ride or look for a white WS6 with a turbo in the rear friday night at Maroso
Old Mar 24, 2004 | 09:24 PM
frcefed98's Avatar
Right ON! I hope you see good numbers from that kit. Be sure to post up some vid's and pics. If you need anyone to host them let me know and I will do that for you.
That would rock if you see 100rwhp from 5psi.
What are your expectations HP/TQ wise from 8psi?
J
Old Mar 24, 2004 | 11:58 PM
1dirtyZ's Avatar
you sure you want to hit the track untuned?
Old Mar 25, 2004 | 12:43 AM
JRL96TA's Avatar
3psi isn't a whole lot. The stock pcm will take care of it just fine.
Old Mar 25, 2004 | 10:35 AM
trtturbo's Avatar
You will see 100rwhp on 5psi. Mine went up 101hp and 126ftlbs. That is all stock fuel system and untuned. What are you going to do for your meth tank? I made a small tank to go behind the front air dam. My washer tank runs into the tank below that way I know when I'm low because the low washer fluid light will come on.
Old Mar 25, 2004 | 11:32 AM
CAT3's Avatar
Restricted User
Wanna post pics of the kit unpacked before install.
Old Mar 25, 2004 | 01:40 PM
wildta's Avatar
Why do you need a meth tank with this STS set up ?
Old Mar 25, 2004 | 01:48 PM
trtturbo's Avatar
At 5psi you dont, but at 8psi it makes the charge air temp cooler
Old Mar 25, 2004 | 01:52 PM
CAT3's Avatar
Restricted User
From my conversation with them, the Alky is needed more so to make up for tuning. The package is sold as a complete kit, no tuning required. The boost, 8#, would kill a stock timing table, and fuel curve. The alky does cool the charge, but in the STS kit the heated charge is less a factor than traditional turbo setups. The alky provides the high octane charge to keep from detonation. Think thats how it was explained. With a tuning, I am sure you would still run into a problem with the 8#, just not as much, although I am not sure.
I am waiting to see this kit, and its performance.
Good luck.
Charlie.
Old Mar 25, 2004 | 02:23 PM
trtturbo's Avatar
I installed my kit at STS and the when we filled the meth tank it was 50/50 water and methanol. This is per the designers suggestion to keep the charge air cool. Thats why is half water.
Old Mar 25, 2004 | 02:33 PM
CHRISPY's Avatar
I wouldnt race it till after the fuel system injectors and tuning. Too risky imo.
good luck with everything!
Old Mar 25, 2004 | 05:07 PM
Come on it only 3psi im going to take about 3 pulls on the dyno friday to make sure shes not leaning out god i cant wait I do think that i am going to enjoy this kit very much cant wait to proove this kit to all the haters and non beleivers plain still stands sea level dyno #s fri along with ET's fri 3 psi untuned install tuesday
Old Mar 25, 2004 | 06:27 PM
White_Hawk's Avatar
It's all good! Turbo guys need the STS just like blower guys have the Powerdyne...
-Geoff
Old Mar 25, 2004 | 06:33 PM
SS00Blue's Avatar
-Geoff
Is that what they call "condescending?"
Hope the numbers work out.
SC-
Old Mar 25, 2004 | 06:49 PM
CAT3's Avatar
Restricted User
Yeah thats condescending at its best.
YOUR.... Good luck, and please do post up the results. I have been following this kits developlment since its start and I am curious to see the results. Maybe not a full blown turbo kit, but hopefully bridge the gap between the multi-thousand $ kits and the guy that wants a little extra + reliability.
Charlie.
Old Mar 25, 2004 | 09:09 PM
White_Hawk's Avatar
What I mean is that is an entry level kit to get people into boost. I did it with my powerdyne and have no regrets. If you guys think that was condescending, it is only because of your opinion of Powerdynes. A good used powerdyne is still about half of what the STS kit is, so I would personally recommend it over an STS. Of course, either a powerdyne or an STS will just get your boost habit in gear, which is what counts!
By the way SS00Blue, there is a call out post for you over in the grudge race section of Motown Muscle , (surprisingly enough, not started by me either ).
-Geoff
Old Mar 25, 2004 | 09:12 PM
gator's 99TA's Avatar
good luck and DEF post your results on this combo. are you coming to the BMP shootout first week of april? F/Y body/Viper shootout?
Old Mar 25, 2004 | 09:15 PM
-Geoff
Rightttttt That was one lame comment, My turbo kit must suck A$$ Because it wasnt $9000+$1500 Install, So i guess i have a low end turbo kit that makes no power, so what makes it like powerdyne
Bring it on Powerdyne
Best $3400 ever spent on my car
Old Mar 25, 2004 | 09:17 PM
Gator Probably not I dont have the time to get out much
Old Mar 25, 2004 | 09:43 PM
CAT3's Avatar
Restricted User
White Hawk, thanks for clearing that up.
