will this cam work with a boosted 5.3
Old Apr 2, 2012 | 10:50 AM
stocks10's Avatar
Default will this cam work with a boosted 5.3
i need to know if this cam will work with my 5.3 its a stock short block with a 72mm turbo..
i have this cam its a. intake XFI 236 exhaust XFI 242 615/612 on a 114LSA +2 degrees advanced i need to know if i will run into pistion to valve clerance problems.
i know it might not be the best cam for my set up but its what i have and im not looing to make crazy power its just a street better on about 13 to 15PSI let me know what you think thanks
Old Apr 2, 2012 | 10:54 AM
redtan's Avatar
That's a bigass cam for a turbo 5.3,
Will it work? Yes. Is it ideal for what you want? Not really but it also depends on what you really want.
Old Apr 2, 2012 | 10:58 AM
02anti_vnm's Avatar
You may have piston to valve clearance problems but that's not the main issue that cam doesn't look very suited for FI if I were you I'd sell it for 275 in the classifieds buy an ls6 cam and run it. You'll make money on the deal and I think you'd be much happier with it. Better drive ability and the turbo will react a lot better
Old Apr 2, 2012 | 11:03 AM
02anti_vnm's Avatar
Haha after rereading that it sounds kinda dumb PTV clearance is a big deal what I meant was that's not the issue you should be worrying about at the moment. You should be worried about getting a cam better suited for a FI 5.3
Old Apr 2, 2012 | 12:40 PM
quik67's Avatar
For what it's worth, I am using a cam very similar. Its a MS3 cam 237/241 .603/.609 with a 113 lsa. It works very well in my 5.3 with twin GT35 turbos. I have tried several "turbo" grinds but always come back to this one . It just makes more power, period! Mine has excellent drive ability. If you already have it, I would try it. Make sure to upgrade your valve springs.
You will need a converter that will flash in the 4000 rpm range. I had a tight 3200 rpm converter before and turbo lag was ridiculous.
