C5 manifolds for turbo kit??
Thanks!!
flow wise the c6 manifolds will work just as well as the truck manifolds.
the c6 hug the block more and might fit better in your applications.
the main reason truck manifolds are used so much is because they clear the steering shaft on fbodies so well. but this is vehicle specific.
I know the truck manis work well and hold up to high hp. I think I am going to use 2 pass side truck manis. The dr side down/forward and the pass side up/ forward.
We are having issues with clearance between the radiator and motor, car/motor and ground. Brake master cylinder, alternator, steering shaft. Basically everything. Going to have some interesting hot side piping.
