Most Power Ever Made with a TC series?
Old Apr 4, 2012 | 03:00 PM
icicleboy's Avatar
Default Most Power Ever Made with a TC series?
As the title states..... I haven't made huge power with one, so that's not what this is about. I'm looking to find out just how far that 68mm F1 turbine wheel has been pushed. I don't care if your car is 4 cyl, 6, or 8. Put down your WHP, transmission, and combo. This is for a single, not twin application.
My specs are :
TC76 .96 OC
640whp through an unlocked auto.
26psi - 35 psi backpressure
pump + meth.
Thanks for participating!
Old Apr 4, 2012 | 05:32 PM
got-a-ls1's Avatar
engine size is definitely a factor here on the turbine flow... so it should be listed. what size is your motor anyway?
Old Apr 4, 2012 | 05:49 PM
joeyc125's Avatar
11 Second Truck Club
I made 650 through an unlocked 4l80e/4wd at 15 psi. The dyno shop didn't have very good fans, so my iat's were a little high. This is on my 365" stock head 218/218/112 isky cam on e85.
Old Apr 4, 2012 | 06:06 PM
icicleboy's Avatar
sorry, my cubes was 231, two less cylinders than you guys as well.
Old Apr 4, 2012 | 06:19 PM
Johnv's Avatar
689 rwhp , load dyno. 383 , m6 , tc 78 1.32 ar, 16 psi boost.
Lots of wheels spin on the dyno, so conservative figure.
Since fitted a t76 thumper, same exhaust wheel and 1.32 ar housing but 76 compressor wheel and much bigger comp housing with 3" outlet an it hits much harder, no numbers yet..
Old Apr 4, 2012 | 09:23 PM
stock48's Avatar
9 Second Truck Club
130mph@4875lbs 4x4 truck. 6.0L, ported 317 heads, JFR Isky 212 cam. Going to be testing the New Tnetics T76/76 soon.
Old Apr 4, 2012 | 09:53 PM
Tally TransAm's Avatar
gonna max out a TC76 as soon as my car is back together, ill be sure to post numbers
Old Apr 4, 2012 | 10:09 PM
Karpellarpy's Avatar
733 rwhp @ 13-14 psi before new intercooler and exhaust. 1.15 a/r and seeing 36+ psi backpressure.
Old Apr 5, 2012 | 12:14 AM
skinnies's Avatar
holy backpressure
5.3 686rwhp 18lbs thru 33" tires, tc78 .96 E85
6.0 720rwhp on 19lbs in a friends truck, tc76 .96 E85
Old Apr 5, 2012 | 06:36 AM
SPRAYED 01's Avatar
Forged 348 15.5psi through locked auto and 9 inch. 675whp at 17 degrees timing pump gas. Its a great little turbo but be prepared to shift early, only made power to about 5100rpm, but it comes on very fast with little to no lag
Old Apr 5, 2012 | 08:31 AM
icicleboy's Avatar
thanks guys! Keep them coming.
I'm really surprised about the thumper hitting harder. I made that 640 on a E cover (2" outlet) and then upgraped to a 60 series cover (2.5" outlet) with pretty much no change at all.
I'm really looking forward to seeing how much BP drops with the new 76 turbine wheel for everyone.
Old Apr 5, 2012 | 09:34 AM
Mas280's Avatar
780RWHP tc78
Old Apr 5, 2012 | 11:38 AM
icicleboy's Avatar
Mas, that's a lot of power through that turbine wheel. Mind sharing specs of motor/combo?
Old Apr 5, 2012 | 11:39 AM
DrTurbo's Avatar
LS1TECH Sponsor
Old Apr 6, 2012 | 12:29 AM
Johnv's Avatar
The thumper has a smaller 76mm billet compressor wheel, quite a bit lighter than the TC78s pressed wheel, thats why it spools quick and hits harder and the freer flowing comp housing is helping the top end flow.
Old Apr 6, 2012 | 11:00 AM
kbracing96's Avatar
So that's about 770 rwhp...
Originally Posted by DrTurbo
Old Apr 6, 2012 | 01:31 PM
Mas280's Avatar
Forged ls3
Ported ls3 heads
Ls3 intake
Lg g6xe cam
E85
T56 in rx7
Car makes 960 with new gts76 turbo
