A2W big dogs inside!!! Cell placement pics/question
What do you guys think?
Option 1, preferred location--Pic of tank sitting in t-top hatch just so you can get an idea of where I'm talking about:
Option 2--Here is the possible solution if Option1 is no good. Only bummer is that it raises my center of gravity and we would have built the cell shorter if we planned it going here.
Wouldn't mounting it low create a siphon once the pump turned off.....possibly overflowing the tank?
Has anyone actually ran a set-up positioned like this before with good results? (High HP, low intake temps on 100* days)
It does look super baller with the tank right in the back window....but we are just bummed we built it tall thinking it would go in the t-top well. We could have built it 6" shorter if we knew we had to mount it high!
To get all the air out you want the cap at the highest point, but with a tank that size you don't even need to get all the air out. You want your pump pulling from the bottom of the tank, so it always pulls water and never air.
With the pump not running, if you open the lid of the tank to put some ice in it, the water from the charge air cooler might run back into the tank, depending on how the lines are routed, if the water can go downhill all the way. I don't think it would matter, depending on how much water your cac holds. Put it together, turn the pump on and watch the water level go down as the pump fills the cac. If you are sure that with that amount of air in the tank that the inlet to the pump will always be submerged, I wouldn't be concerned.
You also want to make sure the water is going in the bottom of the cac and out the top, so it doesn't trap any air.
Put it together outside of the car and just play around with it to see what it does.
i have had several IC tanks mounted in different spots in my car with many different IC's and have made my mistakes.
you always want your drain to be above the top of the IC tanks/lines or you may get into air problems
