Select Turbo Size
Old Apr 7, 2012 | 09:56 PM
F0x Slaughter's Avatar
Default Select Turbo Size
Lets say 350ci redline of say 6000rpm.
Thats 516cfm (at 85% VE)
Say 8lbs of boost. Pressure Ratio of 1.55.
So at 8psi would need 800cfm.
So what turbo would work well with this?
A T76 would fall directly on the 70% efficiency line.
Old Apr 7, 2012 | 10:07 PM
So.jerZ-28's Avatar
4788 or a 80mm would be my guess..
or twin 62-67
Old Apr 7, 2012 | 10:12 PM
Now in regards to determining what you would use for twins how would you go about selecting those?
Would it be half the airflow but the same pressure ratio?
So ~30lbs/min at 1.55 PR?
A Y2K T-80 would fall into 70% island.
Old Apr 8, 2012 | 11:05 AM
the big kahuna's Avatar
those borg waner,s 75mm work great 1100 hp if you get the right one that's what i would stick on it
Old Apr 8, 2012 | 11:31 AM
I looked into twin T61 and they seem they would work great anywhere from 6psi up to 20psi.
