H/C with D1SC questions
- Are my heads ok for a D1SC kit?
- I'm guessing the cam would have to be swapped out?
- I'll be getting MWC 9" probably next year, are 4:11's still ok?
- Is the Ractronix F99 hotwire kit suitable?
- Will I need bigger injectors than 42lb?
- Will I have to do any internal work to handle the HP?
Any other opinions/suggestions welcome....Thanks!
Cam would work but you would gain with a am more geared towards a blower.
60# injectors would be close.
Bottom end could last 65k miles or go out the fist WOT run you do.
If you have a decent tuner there is ussually no issues.
Thanks! Not too bad for a budget build.
So some say cam is ok with a good tune, some say to switch.
