another what oil would you use
Old Apr 8, 2012 | 04:56 PM
edge04's Avatar
Default another what oil would you use
Seems like most on here like Rotella or VR1. I would like to run a full synthetic. What vescoisty would you rec on a FI motor (TVS2300)? Clearances are ROD .002-.0022 MAIN .0012-.0015. Midwest so temps range from 50-95. Engines been dynoed and have about 500 miles on it. Seeing what you guys would run.
Old Apr 8, 2012 | 10:46 PM
code4's Avatar
Been running the synthetic rotella on my daily driver FI truck. I like it.
Old Apr 8, 2012 | 11:10 PM
yoshgixxer's Avatar
I always herd lots of good things about rotella oils. My buddy has been using it in his turbo sbf mustang for over a year now and i used it on my last turbo stock bottom end ls1 with no issues that were oil related. I recently switched to valvoline VR1 50w becuase of its proven compatibility with E85 fuel. So far so good.. Either one is probably a safe choice
Old Apr 9, 2012 | 05:57 AM
edge04's Avatar
I have straight 50w VR1 in it now. should I switch to 20-50?
Old Apr 9, 2012 | 08:22 AM
yoshgixxer's Avatar
You can use 20w50 if its cold were u live. Makes it easier to crank over in the cold. Either way there both 50w when hot
Old Apr 9, 2012 | 08:48 PM
edge04's Avatar
I'm a little nervous about the MAIN clearences, those seem awfully tight. My tuner said that the oil wasn't getting hot on the dyno but don't you think 50w is a bit thick for those? Maybe run a 20-50 synthetic which is a bit thinner right?
Old Apr 10, 2012 | 03:33 PM
Alpha's Avatar
I would recommend Brad Penn 15W-40 High Performance Oil. I've been using it for a long time with great results.
