Aero Force
Old Apr 1, 2012 | 05:58 PM
lbm13186's Avatar
Default Aero Force
Was wondering if anyone has used the aero force gauge to monitor your Wideband afr, oil and fuel pressure or boost??
just wanted to see what people have used it, and used any of the sensors kits and how they liked them
or if any one has a suggestion on sensors that i should use
Old Apr 1, 2012 | 08:57 PM
fast00ls1's Avatar
I would like to know this?
Old Apr 1, 2012 | 10:37 PM
mpatton's Avatar
I have one never used it for boost. But everything else is pretty legit on it. Mines from my old Gto but it still reads practically everything. Great guage in my oppinion
Old Apr 2, 2012 | 05:37 AM
lbm13186's Avatar
mpatton do u use any of the additional sensors that you can buy with it or do you use it just for what the computer monitors??
i have one of the units and i was wondering if anyone has used the sensors kits that you can buy
thanks guys
Old Apr 2, 2012 | 07:56 AM
LS1NOVA's Avatar
Interested as well.
Old Apr 2, 2012 | 08:06 AM
edub80's Avatar
I was just about to make post about the aeroforce too... in for the info.... I'm wanting the gauge and the wideband sensor kit too... just want some info of how accurate it is
Old Apr 2, 2012 | 08:17 AM
conan's Avatar
I have one, I usually watch the knock, and timing on my gauge. I have a wide band and boost gauge separate. I would buy one again it has been helpfull keeping an eye on certain things.
Old Apr 2, 2012 | 06:28 PM
lbm13186's Avatar
Has anyone used the sensors that you can buy with the aero force gauges.... please let us know how you liked them
Old Apr 3, 2012 | 02:34 PM
lbm13186's Avatar
so i guess no one on this sight has used the aero force for monitoring anything that uses the sensors?????
Old Apr 3, 2012 | 05:12 PM
stealth355tpi's Avatar
Had the dual setup for awhile now. In the process of going FI so I just got the fuel pressure sensor and hoping to get boost off of the map reading without having to buy that sensor too.
Old Apr 3, 2012 | 05:44 PM
07MCSS's Avatar
I use the fuel pressure sensor. I got a 5 volt input per the instructions and set the parameters outlined in the instructions. It didn't show proper fuel pressure. I contacted them and the ordered their power supply for it. It still doesn't read the fuel pressure properly. They suggested that I send the sensor in for testing. I put my mechanical gauge back on.
Old Apr 4, 2012 | 10:10 PM
lbm13186's Avatar
good info to know guys please keep it up, i would like to know if more people have tried the sensor and had luck or not with them??
Old Apr 5, 2012 | 10:04 AM
ArklaTexan's Avatar
I have 3 of these guages. Two Interceptor and one analogic and they all match. I use the wideband, fuel pressure, and boost(all sensor based) and the use scan for the other parameters.
Old Apr 5, 2012 | 01:19 PM
BadgeZ28's Avatar
I had my gauge updated to the latest software. Bought the add on wideband kit but never installed it. A nice feature is the ability to set a built in warning light to go off if reading go out of a certain range. Could save an engine.
Old Apr 5, 2012 | 01:43 PM
5 Liter Eater's Avatar
I have one and I pipe my MTXL wide band output to it as well as the Aeroforce FP sender. Only complaint is the FP sensor heat soaks and reads artificially low. I have not heard good things from others about their FPG senders either, numerous ones have tanked and they say not to power the FP sender without it's output going to the AF gauge but I have not run into this, I'm tuning with HPT a lot so the AF is not connected then and other than reading low it has not malfunctioned. Other than that it's great to have. I have a 2.5 bar MAP for my SD tune and it reads boost through the ALDL along with everything else. I have my alerts set up so that if I'm over 4# of boost and leaner than 12:1 it triggers.
Old Apr 5, 2012 | 02:12 PM
mikey67's Avatar
I bought the fuel pressure sensor for my dual set. Compared to the mechanical gauge I had on my fuel rail it reads about 2-3 psi less. I can live with it, but I question the accuracy of the Aeroforce sending units. The PCM parameters seem to work very well however so overall I'm happy with it. It packs a ton of capability in a small package.
Old Apr 10, 2012 | 07:27 PM
lbm13186's Avatar
ya iv heard about the same from everyone that it is a good tool to monitor everything the computer reads but not much more than that... so i think that im going to use reg gauges to read everything (wide band AFR, Boost, Fuel Pressure)
