Anyone have a bmr turbo k member with umi solid motor mounts???
This **** seems to not line up! The stock mounts work fine, the umi's don't line up anyone run into this problem with this combo????
My motor is out of the car and the the k member everything is new so I tried to slap it on to make sure everything fit and I ran into this problem. Cars suck
The UMI mounts are built to the exact dimensions as the factory mounts. Make sure you have the offset of the motor bolt hole the right way.
The solid mounts don't allow any flex or movement like the factory rubber mounts do. This means the pedestals on the k-member need to be perfect. If the tolerances on the k-member motor stands are different than factory the mounts won't go on easy.
Wow....when I tried it with the stock k member they Didnt even line up, I called umi and they said try flipping the mounts so the side that says up is facing down, works perfect now with the stock k member and the bmr turbo k member, note to umi, please fire whoever screwed that up!
When i installed mine with umi mounts and bmr turbo k... i tried installing with up side up and trans mount would have to move back.. soo i installed upside down and no problems however when i goto redo front susp in a week or so im gona try again
