Fireball Twin Turbo Third Gen Camaro Build thread
#123
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
when the hell is this heat wave gonna break? I'm not going to be working outside in the garage when its mid 90s out and 100% humidity ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Planning on pulling it in the garage this weekend (supposed to be a bit cooler) and start ripping out the power/drivetrain. still has a 400small block in it (just the shortblock), T350 trans and 10bolt. That along with the front kmember and suspension has to GO![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Hopefully my BMR Kmember and SFCs will show up early (bought from Jegs on my racer's discount) and estimated ship date was 7/25.![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
If they show up early, then I can get the LS2 mockup block and glide in place to start figuring out what I have to work with
#125
ProFlo will NOT fit under the factory hood. I have tried.
You don't need to minitub a 3rd gen to tuck a 15x10 wheel.
15x10 with a 6.5" backspace is what you will need with a stock width rear end:
Here is my 15x10.275 tucked under
![](http://i110.photobucket.com/albums/n87/dflyn17/IrocZ/2012-03-10115356.jpg)
Good luck trying to keep that torque arm crossmember from scraping anything higher than 3". Just be careful on the street.
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#136
worked on it all morning. Got the old SBC shortblock, the old T350 tranny and the stock k-member out and did a bit of cleaning until I cut my finger pretty bad on a sharp edge
. 28 years of grime sucks to clean ![Bomb](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bomb.gif)
![](https://ls1tech.com/forums/attachments/forced-induction/364663d1342890730-fireball-twin-turbo-third-gen-camaro-build-thread-6-21-12_1.jpg)
![](https://ls1tech.com/forums/attachments/forced-induction/364664d1342890730-fireball-twin-turbo-third-gen-camaro-build-thread-6-21-12_2.jpg)
Got the BMR k-member installed. Need to get some long bolts so I can install bolt the ls2 mockup block into the chassis...
![](https://ls1tech.com/forums/attachments/forced-induction/364665d1342890735-fireball-twin-turbo-third-gen-camaro-build-thread-6-21-12_3.jpg)
