Procharger Plenum and Meth Injection?
Old Apr 21, 2012 | 05:52 AM
MstgKillr's Avatar
Default Procharger Plenum and Meth Injection?
I am in the process of installing an Alky Control dual injection methanol kit. Can I install the injectors, one on each side of the ATI aluminum plenum that is used with the twin intercoolers. If so, I was thinking of relocating the IAT sensor to the blank pipe where the MAF was supposed to go and then run a SD tune.
Old Apr 21, 2012 | 10:13 AM
Julio's Avatar
Nozzles can practically go anywhere. You need to try and make the nozzles the highest point of your system. Pump is lowest. Tank in between.
The only thing is you don't want nozzles pre MaF as that can mess up the sensor
Since your going SD.. Then it doesn't matter.
Yes on IAT after meth nozzles
