View Poll Results: What size feed line for PT88
3an
0
0%
4an with restrictor
3
27.27%
4an without restrictor
8
72.73%
Voters: 11. You may not vote on this poll
Oil Feed for PT88
Old Apr 2, 2012 | 09:41 AM
1Legged60ftHnter's Avatar
Default Oil Feed for PT88
What size do I need to run? I have seen people that run 3an, 4an with a restrictor, and others that run unrestricted 4an. I already have a 3an setup that I was going to use if it will work... hopefully it will. I will be running a 10an drain line. Not sure if any other variables come into play here or not.
Old Apr 2, 2012 | 12:45 PM
drumbo87's Avatar
Is your turbo ball bearing or journal bearing? I ran unrestricted -4an on my old setup with no issue.
Old Apr 2, 2012 | 01:12 PM
98Camarod's Avatar
x2 for both.
Old Apr 2, 2012 | 03:43 PM
5mall5nail5's Avatar
Generally run a -4 on all setups with 0.065" restrictor on dbb and no restrictor on journal.
Old Apr 2, 2012 | 04:10 PM
Martin718's Avatar
So on a pro mod 88 no ball bearing I can run a -3 or -4 non restricted feed line?
Old Apr 4, 2012 | 08:54 AM
I'm not sure whether it is journal or ball bearing. How can I tell? Either way it looks like I will be ditching the 3an line I already have. lol
Old Apr 4, 2012 | 09:12 AM
Sweet_SS's Avatar
If it's non ball bearing then use -4AN line unrestricted. If it's ball bearing then you will need to restrict it. Journals need more line pressure than the ball bearing turbo's.
Old Apr 4, 2012 | 10:12 AM
Martin718's Avatar
Makes sense thanks
Old Apr 5, 2012 | 07:28 AM
smokinHawk's Avatar
i used a 4an unrestricted, with a 10an drain, no smoke.
Old Apr 5, 2012 | 08:37 AM
dschmittie1's Avatar
When I had a PT88 I ran a 4an unrestricted and 10AN drain
Old Apr 21, 2012 | 10:01 AM
Next question: What size is the fitting that goes into the turbo? 1/4 npt? I noticed most of the oil feed "kits" have a 1/2 npt fitting, but thought that sounded a little small to go to 4an.
Old Apr 21, 2012 | 10:08 AM
Julio's Avatar
Mid frame 88 has 1/4 NPT thread. I use a -12 return
Just get a 1/4 flare to 1/4 NPT adapter for the feed
Old Apr 21, 2012 | 10:11 AM
Thanks for the info.
I will be running a -10 return since I already have it and I don't think it will cause any problems from what I have been reading... even with an unrestricted -4 feed.
Old Apr 21, 2012 | 10:24 AM
Julio's Avatar
I had issues with my -10
If you end up with oil on exhaust you'll have your answer
