em i getting a good deal ??
Old Apr 26, 2012 | 11:15 AM
lsxTAlemy's Avatar
Default em i getting a good deal ??
a buddy of mine is giving me a switzer turbo he says is 78 to 80mm he was going to mike it for me to tell me how big it is. not sure if is t4 or t6 split housing. he says it goes for 1400 new its freshly rebuilt no play at all. he's giving it to me for 650 whats u guys opinion
what can i expect to get out of it ?
Old Apr 26, 2012 | 11:52 AM
lsxTAlemy's Avatar
im not sure if i spelled the turbo brand correct that's more or less what the name sounds like looking to do a front mount
Old Apr 26, 2012 | 12:38 PM
lsxTAlemy's Avatar
schwitzer now it turns out the its a 60mm and the hot side is 68mm 151 ar should i even get in to this he's telling me that ill get the car 650 with no problem with it. im new to this need some help
Old Apr 26, 2012 | 01:09 PM
lsxTAlemy's Avatar
68 views and no one can tell me anything?
Old Apr 26, 2012 | 01:24 PM
2000RATA's Avatar
If I read that right it would take 2 of them. One won't do it. Too small.
Old Apr 26, 2012 | 01:31 PM
lsxTAlemy's Avatar
ok that's what i thought after he told me it was a 60mm
what size should i be looking for? its going to be a front mount. i was looking at ebay ones but im scared of them, even tho iv seen them last pretty long. i been told 76mm 78mm 80mm and a .96 to 1.05ar hot side but im not really familliar with any of this im looking for an 800hp final goal
Old Apr 26, 2012 | 04:00 PM
BOBS99SS's Avatar
Captain Double Post
As far as the ebay turbos go i have seen some people have very good luck with them,if i got a budget turbo it would be from on3
Old Apr 27, 2012 | 06:14 AM
lsxTAlemy's Avatar
yea those are the ones i heard good stuff from
Old Apr 27, 2012 | 10:32 AM
TermnEatr's Avatar
Master power turbos aren't bad either
Old Apr 27, 2012 | 11:02 AM
lsxTAlemy's Avatar
thanks guys im going to hold off for a lil bit i already have the truck manis and the carb style intake efi what size should i look for t76 t78 t80 ?
Old Apr 27, 2012 | 11:12 AM
TheLS1Lover's Avatar
I see that your stock motor, do you plan to forge it? I would say a 76mm, something like a PT7675, TC78, or along the lines of an S475. All of these will reach your goal. What fuel system are you running?
Old Apr 27, 2012 | 11:20 AM
lsxTAlemy's Avatar
right now fuel is stock. i will be getting a walbro 255 soon. i already need it for my nitrous set up that I'm running now. the car will end up with a 370 ci at the end but that's long term. stock crank forged rods and pistons. heard one of the best things would be and ls6 cam
Old Apr 27, 2012 | 12:18 PM
Add another 255. 80lb injectors and you have room to grow.
Old Apr 27, 2012 | 12:38 PM
lsxTAlemy's Avatar
thanks twin 225 and 80# should be good for how much id like 550 and then work my way up car is not a daily driver
Old Apr 30, 2012 | 07:15 AM
lsxTAlemy's Avatar
^^? and what size will best fit my power goal on a 370ci
