what's a good head and cam package for ls1 turbo
what would be the best set-up curr. have 42lb injectors 60-1 turbo kit making 9psi ported throttle body and ls6 intake i upgraded valve springs and push rods
thanks dan
thanks dan
I'd go with a set of patriot stg2 6.0ltr FI 72cc heads and have them maybe open the chambers up a little extra to drop your compression even lower. For the cam, Cammotion recommender a custom cam to me for my setup. the specs are.
Dur. int. 226
Dur. exh. 218
Lift. int. .574
Lift. exh. .564
LSA. 116
ICL. 113
How much power are you making with your kit? Do you have the 2.5in or 3in down pipe?
Is this in a M6 or A4?
Dur. int. 226
Dur. exh. 218
Lift. int. .574
Lift. exh. .564
LSA. 116
ICL. 113
