Turbo Sizing Question.
Old Apr 27, 2012 | 12:25 PM
mefreema's Avatar
Default Turbo Sizing Question.
I have a friend that is going to be putting a turbo on a LS2 and was wondering if this turbo he is looking at is too small? I though it looked too small especially with the T3 turbine. It is going to be a front mount. What are your opinions? It will be intended as a low boost application to spool quickly on the street.
Turbo specs:
Compressor: 4" inlet, 2.5" outlet
Turbine: T3 flange, 3" V-band
Compressor: .70a/r
Turbine: .84 a/r
Compressor Wheel: 91mm/61mm
Turbine Wheel: 74.7mm/62mm
Old Apr 27, 2012 | 03:26 PM
SPRAYED 01's Avatar
Way way to small, that will choke up in the 4k rpm range.
Old Apr 27, 2012 | 05:29 PM
TheLS1Lover's Avatar
^ Defiantly, I'm not sure that I would run TWIN T3s. Let alone a single.
Old Apr 27, 2012 | 09:50 PM
mefreema's Avatar
thats what i thought, thanks for the replys.
