Turbo Cam ???
LS1 ~44* 116 LDA 196/207 @ .050
LS6 ~40* 117.5 LDA 204/218 @ .050
LS9 ~39* 122.5 LDA 211/230 @ .050
LSA ~39* 119 LDA 198/216 @ .050
So why is it then GM for their factory Supercharged engines are running less valve overlap and a wider LDA than their non-supercharger engines? Not one of their engines is running a Reverse Split Duration cam either.
I'm just wondering because if my the information I've read is incorrect I'd like to be corrected.
Stock 1987 Buick Grand National Cam-
38 degrees overlap
192/196 @.050
107 LSA
Pretty tight LSA on a restrictive turbo system and I'm fairly certain the turbo doesn't start to spin backwards.
Basically what I'm saying is, repeating (a somewhat skewed perception) of what you read on that website does not translate into reality. There is no reason for super wide LSA's or an exaggerated delay for IVO even on a less than ideal turbo system.
ever get the feeling you waste your breath?
my buddy is running 5psi (yes 5) on a 76mm and wants to put heads on the thing when all he needs is a gasket swap... people make it really difficult to let you help them sometimes.
The other type of compressor surge is when you have a compressor that is moving more air than the motor can ingest at WOT. Oversimplified.
Also, supercharged cam theory is far more similar to N/A cam theory than it is to turbo cam theory.
38 degrees overlap
192/196 @.050
107 LSA
How about TC78 turbonetic with 1.15 ar. Now the 317 heads are stock you guys think is good idea porting them and put 2.08/1.57 valves or just use that money in the turbo? I already have the new set of SS Valves.
What are the advantages of a 112.5 vs a 115+3 ?
I don't know turbos or cams, I am running a 372 iron/LS3 topend with a gt91.
My builder ordered a custom grind as follows:232 234 .595/.576 115+3
The actual LSA figure doesn't really matter, what it all comes down to is the valve events. By that I mean, choose the valve events and the LSA is a byproduct of that (not the other way around).
After many years of building and testing different combinations, our preference is to run turbo cams with similar valve events as something you would use on a naturally aspirated engine along with relatively mild lobes that maintain stability at high rpm (7500+ if the turbos are up to task).
Your cam will work great, I see no problem with it even though it is slightly different than what I would use.
I don't think you would see much gain with anything much bigger than an LS6 cam, it's just not going to make up for the turbine inefficiency.
For example, by playing around with the cam from stock to -anything you might see a 30, 35hp difference.
Now, if you tossed a PT7675 on there you will probably see a couple hundred HP difference, even with the stock cam, which is why I think the money is best spent there.
Kurt
