Huron Speed, on3 turbo, and 5.3 dyno results with vid!
#64
LS1Tech Sponsor
I am a dealer for BMR however so I can get their polished rad support if it is a deal breaker as well!
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic36191_1.gif)
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#72
LS1Tech Sponsor
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Jon
__________________
#74
LS1Tech Sponsor
The install is VERY straight forward, and if you have any questions, anyone can contact me with questions. I have not had anyone call me with questions during install yet other than on the alternator relocation kit. Very simple and straight forward!
We currently do not do installs but will be set up for it in the near future, possibly this winter.
__________________
#75
Yes he is right, the kit is very easy to install. And everything is pretty much bolt on.
Compression ratio would be 9.5:1. I believe thats what a stock 5.3 is...
My fuel setup consist of 80# injectors, stock feed line, evap used for the return, walbro 255 intank. Also a external Bosch 420 pump that is sumped in the stock plastic tank, and I have the two pumps "y" together before the factory fuel filter. Hope this helps
#80
LS1Tech Sponsor
__________________
