noob ????
Old May 5, 2012 | 01:54 PM
inkis4ever's Avatar
Default noob ????
Im debating between running a big single or smaller twin setup. From research so far if I went single I would be leaning toward a pt88. I havent found much info on twins. Im considering a pair of these T76 0.68 A/R P Trim.
The motor is an lq4 ported 317's not decided on cam, forged rods and diamond pistons. It will be backed with a 4l80e trans. Im concerned about the 0.68 a/r being too low and choking the engine. Any input or suggestions would be great. Thanks guys.
Old May 5, 2012 | 05:27 PM
98Z28CobraKiller's Avatar
Restricted User
Twins are easier to package in a tight space like the front of a late model Fbody. The twin T76's with the .68 a/r housings will work great for a good all around street/strip warrior on stockish cubes. It will also spool a little faster and have the potential to make more over all power than the PT88.
The down side to the twins is that it requires more plumbing and is a more complicated setup over all. This makes issues more difficult to diagnose and will likely make for a more expensive kit.
Old May 5, 2012 | 05:54 PM
TurboS10's Avatar
Twin T61=PT88H which is a T88 compressor.
Two numbers to look at on the turbine.
A/R and exducer/outlet size.
A .96 a/r GTS (75mm) will not flow the same as a .9 a/r 111mm.
A/R is area divided by radius. Many ways to get same a/r.
Twin p trim (65mm) will support around 1400 fwhp. So twin T61 p trim .68-.81 a/r will do about 1400 fwhp.
Assuming 355-390 CID.
You didn't say what you wanted for power or use so hard to give an opinion.
Old May 5, 2012 | 06:05 PM
TurboS10's Avatar
I know of one guy that ran 8's w/a 400 and twin MPT70 p trims.
He swapped to T76 p's IIRC and didn't like it and went same or slower ET.
Twin 76's is way more than a stock head/crank build.
Stock48 on here runs 9.7's at ~5200lbs 4x4 6.0 with a GT76.
That's basically a 7685 T4 setup. IDK what compressor cover he has. Either GT45 or GT47.
Old May 5, 2012 | 07:15 PM
inkis4ever's Avatar
Sorry guys shoulda been a little more specific. Basically what Im looking for is around the 700-800 rwhp range. And yes the motor is a 370ci. I would like to be in that range without working the turbo or turbos to death, and also have room to grow if I so choose down the road. The car will mostly be street driven a couple days a week but taken to the track maybe 3 or 4 times a year.
I know the 76's are pretty large for twins but also a little small for a single. The only reason I was looking at these 76's is due to the .68 a/r which I think would make them spool fairly quick. If they were .96 a/r 76mm then that would be def overkill for my build right???
Old May 5, 2012 | 07:49 PM
Restricted User
They will work. If you look on the fast list at the top of the page, BonnarLS1 has twin TC78's w/ 81 a/r exhaust housings on an LS3 (6.2L) and they work fine but are just a touch laggy on the street. He's only pushed about 15 psi thru them so far. Those same turbos came off LS2Formula's car and ran 7.8's behind a 422 LSX. With the smaller .68 housing on a 76mm, it'll work great on the 6.0 , be responsive and should take a long while to outgrow. You can run 600 rwhp or 1400+. Just depending on how willing you are to beef up the supporting mods in order for the setup to survive the power and ofcourse, testicular fortitude.
Old May 5, 2012 | 07:50 PM
inkis4ever's Avatar
would I be better off instead of t76 twins going with t67's with a .68 a/r? Or just say screw the twins and go with a pt88 .96 a/r? Im really undecided. I know the twins will be more expensive and probably a bigger pain to tune as well. But ya gotta love the holy sh*t factor of popping the hood and seeing twins.
Old May 5, 2012 | 07:53 PM
Restricted User
If I had the money and not class racing, i'd do twins and I'd just do the 76's. Provided everything is mechanically sound, the tuner doesn't care if it's twins or a single.
Old May 5, 2012 | 07:54 PM
inkis4ever's Avatar
Awesome thanks for the responces guys. 98z28cobrakiller your def making me lean toward the twin 76's. So if the tc78 with .81 a/r is a bit laggy the 76 with .68 a/r should be a bit more responsive. Im also not looking to rev the hell out of the engine to hopefully get a reasonable amount of life out of it. I would say Id like to run in the 6500 rpm range.
Old May 5, 2012 | 07:57 PM
Restricted User
That's fine. You just have to have the correct converter.
Old May 5, 2012 | 07:58 PM
inkis4ever's Avatar
Im pretty fortunate in that I have a friend who I tattoo and he owns a shop, so I get his pricing on all my parts and we trade out for labor. He def knows how to build a quality setup for me but I will have to look elsewhere for a tuner. But overall he will be saving me a substantial amount on many of the parts and also any fab work that I wont be doing myself.
Old May 5, 2012 | 08:00 PM
inkis4ever's Avatar
Do you have any suggestions as far as a cam and converter? Something for both that will have good street manors also with the cam I would like it to be streetable of course but still have a "cammed" lumpy sound
Old May 5, 2012 | 08:16 PM
TurboS10's Avatar
Twin 61's will do what you want and spool faster.
But they aren't big enough to go 7's..
61-76 can have the same size compressor housing....4x2.5.
No one will know the difference with the air filter on.
TC w/66-78 come with a 68mm turbine.
The smaller compressors are either 65, 62, 5x.
For a mostly street car with your HP goals, 61-66mm twins is how I'd go.
6162's .81 exh w 4x2.5 compressor to be specific. 6165's for more top end.
INTMD8 did 800rwhp w/T56 with 6165's on a GenII w/ 218/218 115 cam.
Old May 5, 2012 | 10:11 PM
inkis4ever's Avatar
damn decisions decisions. I think Ill talk to the tuner for some input as well. I just did some research on theturboforums and after researching there Im going to go with 98z28cobrakiller and do the twin 76's with the .68 a/r. Apparently hotrod mag did an article with a 5.3 and the same spec turbos and made over 1200hp. So a 6.0 with a pair should have no problem putting down 7-800rwhp. Oh and if its ok with you 98z28cobrakiller I might pm you here and there with some ???'s. Thanks for all the input guys. Build thread coming soon.
Old May 6, 2012 | 03:18 PM
2000RATA's Avatar
At the risk of hijacking this thread, thank you TurboS10. The 6165's are exactly what I was sold when posing the same scenario when I bought my twin kit. I wanted 900 rwhp possibility with 98% street nasty. With being a street mostly car I wanted it to have no lag if possible. I also read a guys post here with twins who made 1300rwhp with .68A/R. Easier to get exhaust through 2 exhaust housings.
