Precision Turbo went bad twice in 3 months....now what?
You know I have been following your build for a while Wicked so I feel your pain. People have gotten mixed results with Ebay units. Why not sell the working precision turbo, and bolt on the Hong Kong Phooeys (one of my favorite cartoons from the '80s) and see what happens. I doubt you want to spend $4k for turbos...just yet.
^^^ I would do this also provided its rebuilt for free and you get to use it again.
If not, go with a Comp unit. I dont know how you guys are paying so much for your oiless units. I got quoted cheaper.
I had already swapped them this time. That is why I am saying that the other turbo is fine and nothing has happened to it and it has never been rebuilt.
I'm not sure what has been done yet but I would send them both and fully inform them of the situation also a y fitting would be better and make sure both feed lines are equal length after the y
Here is a decent picture of my set up. It wasn't complete yet. I had shortened some of the lines some more to try and make everything as even as possible on the set up. I don't think anything looks strange and there may be about an inch difference in hose length from turbo to turbo. keep in mind though when I swapped sides the same thing still happened to the same turbo. That has to make me think it is not anyway I have it set up.
I have a Comp. Oil-Less 76 and LOVE IT! (Rear Mount...)
1000 miles on the set up and SO FAR rock solid!
My friends 550+rwhp Precision 6262 powered S2000 had a BRAND new Journal Bearing 6262 and within 2000 miles it got a **** load of shaft play and the wheel started hitting the housing... He bought a BRAND NEW center section from precision threw it in there and after 500 miles or less the wheel started hitting the housing AGAIN!
Hes pissed.
Hes pissed.
Hes pissed.
Hes pissed.
#33
You should email dennis this thread. If this is how they handle problems I won't be buying one that's for dang sure. Screw that, for 1k you can buy a nice turbo.
#34
Today, after I took the turbos off I put each line in a bucket and started the car for one minute. The buckets are dirty but as you can see there is quite a bit of oil coming out in 1 minute.
#36
#38
#39
