ATI/Procharger rebuild help
Old May 14, 2012 | 12:53 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Very cool. One day, my D1SC might grow up and be replace with an F-series blower....one day, maybe.
Old May 14, 2012 | 02:00 PM
SeeTSvee's Avatar
I'm just looking forward to the array of **** that is gonna break once I get it all back together haha!!
Old May 14, 2012 | 02:20 PM
vmapper's Avatar
On the V... yea, no doubt.
Im always saving money for the next catastrophe as well.. 6300+ for a rear end fix alone, then add the LS9x clutch for another 1400, really sucks.
Depending on if you are using the GTO bracket or the corvette for the V.
The biggest blower you will get in there is the D-1SC if your using the GTO main bracket. The F-1A is 5/8" thicker (i think, i have the actual number at home). Meaning you would have to cut through the strut tower to get some sort of inlet tube up to it. I decided to avoid that route.
Its interesting to see someone rebuild their own.... Most i have done is the simple re-clocking.
Old May 14, 2012 | 08:50 PM
SeeTSvee's Avatar
Well I got the output shaft and impeller out and the seal and bearing replaced. I'm gonna press the inner output shaft bearing on tomorrow and hopefully throw it all together tomorrow night. I'll document everything for a future "sticky" maybe.
I had to get crafty for a fixture to press the impeller off the shaft. It was hilarious but it worked well...
Old May 14, 2012 | 10:07 PM
xFLG KING PIN's Avatar
Sticken it to poorcharger, keep up the good work man. I will be joining you after I renovate my new house...and then move in it.
Old May 14, 2012 | 10:31 PM
NemeSS's Avatar
Old May 14, 2012 | 10:53 PM
SeeTSvee's Avatar
Thanks brotha!! I hate paying money for **** 'I think' I can do, haha!
Old May 15, 2012 | 01:56 AM
1toofastlt1's Avatar
May have already been said but stick the head unit in the freezer and the impeller in the oven at 400deg. After about 30 they will slip together very nicely. That's how I did my v7 ysi
Old May 15, 2012 | 08:34 PM
SeeTSvee's Avatar
Head unit is in the freezer as we speak, all seals are in and am cleaning everything up one last time before reassembly tomorrow.
I had to have my machine shop pull the oil slinger bearings. Didn't have any access to anything small enough for them...
Old May 20, 2012 | 08:48 PM
Any updates?
Old Jul 3, 2012 | 05:27 AM
toxshox's Avatar
i too am very interested in photos and how to's on how the tear down and rebuild is done.
Old Jul 12, 2012 | 11:54 PM
  #32
Tirefire's Avatar
How did it go!???
