ATI/Procharger rebuild help
Anyone who may have done this before-am I doing this right? I heard it takes a lot of force, but I dont want to break expensive **** simply because I didn't ask before I pressed. Thanks in advance!
Robbie
P-1SC have straight blade impeller
The P-1SC-1 uses the same impeller type (straight and curved impeller blades) as what is in the D-1SC, except its diameter is smaller in the P-1SC-1 (which happens to be the diameter size of a P-1SC).
Another term used is H.O. (high output) for kits. These H.O. kits, such as with a GTO or corvette procharger kit, is given a 'baby' D-1SC so to speak - the P-1SC-1.
some pics of a P-1SC-1 (on the right) vs a D-1SC
http://forums.corvetteforum.com/c5-f...sc-vs-f1a.html
P-1SC:
http://t1.gstatic.com/images?q=tbn:A...GcaEEYjrj2MWtE
You can buy an aftermarket P-1SC straight blade that is Curved. Post# 79
http://i252.photobucket.com/albums/h.../p1stg2ccw.jpg
Many people when discussing, use the term P-1SC, when in fact they actually have a P-1SC-1. There is a VERY Large difference in using a P-1SC vs a P-1SC-1. To give you an example:
A P-1SC maxed out on a stock LS6 can only make 6.5psi (at 3300 ft). I learned the hard way, when everyone says P-1SC, in their vehicle, able to make way more boost, when in fact (after buying brand new from procharger a P-1SC, they actually have a P-1SC-1... P-1SC are used for 4.6 L or smaller IMO.
Sorry to drift the subject at hand.
Impeller should be off this afternoon!!
