For those that always ask will 317's make power. 1000+ inside w/ vid
Old 09-13-2012, 01:06 PM
  #61
StangBanger317's Avatar
Makes me regret getting Mike Duke ported 317's!! Lol
Old 09-13-2012, 02:41 PM
  #62
LT1 ANDY's Avatar
I'd lean more that the GT47 turbine is out of steam, the housing may move the power to a higher range. great numbers nonetheless
Old 09-13-2012, 02:57 PM
  #63
Rickys S/C Z28's Avatar
if my car makes this kinda power (408 ported 317s and a 88x) Ill be very happy
Old 09-13-2012, 05:43 PM
  #64
TINKRD's Avatar
Originally Posted by 6ltr
Off topic question
Who built your turbo kit?
Local guy. It's a one off kit.
Old 09-13-2012, 05:45 PM
  #65
TINKRD's Avatar
Originally Posted by Martin@Tick
Boost has a huge effect on the springs that should be used.
You're creating more cylinder pressure than you ever could N/A.
What lift are your springs good too and what lift is your cam?
If you have plenty of room to shim them before you reach coil bind, I would for sure shim them to raise the seat pressure.
588 lift and they're Manley dual springs.
Old 09-14-2012, 04:19 PM
  #66
Louis's Avatar
It looks to be turbine related. I'd measure backpressure pre-turbine.
Old 09-14-2012, 05:02 PM
  #67
js2fst's Avatar
I would do a LS 7 before I risked pressure plate failure with a spec
Old 09-14-2012, 05:15 PM
  #68
blackonblacksls's Avatar
I have see. Valve float before on the dyno and the graphs don't look like that...
Old 09-30-2012, 08:33 AM
  #69
overhere's Avatar
Very nice numbers. This setup ever been to the track? Would also really like to see back pressure
Quick Reply: For those that always ask will 317's make power. 1000+ inside w/ vid
