How big of a Procharger with aster bracket
Old May 29, 2012 | 03:50 PM
js2fst's Avatar
Default How big of a Procharger with aster bracket
How big of a Procharger can I do?
Old May 29, 2012 | 05:55 PM
02LS1ram's Avatar
I think you can run up too any of the F1 series of blowers with the aster bracket, if I rember right I think someone made up to 22psi with it but that was at it's limits.I could be wrong tho. Aster will problay chime in on this one
Old May 29, 2012 | 06:05 PM
I8UR4RD's Avatar
good question. in it for answers.
Old May 29, 2012 | 06:16 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
I think the more important logistical issue is what to do about the inlet on the bigger blowers since the radiator is precariously close to the blower. Of course then there's the issue of the limits of the 8-rib belt.
Do they make a narrow cog setup that's about the width of an 8-rib?
Old May 29, 2012 | 06:33 PM
js2fst's Avatar
Exactly I am curiosity Procharger might be next part of project next! I got to hurry wife's wants a boat!! I say finish this project on car and get seafood jet boat and pull it with ta
Old May 29, 2012 | 08:02 PM
LS1RedZ's Avatar
Yes the inlet is what kills you. I got my F1A on and it was hitting every damn thing. My mod this winter will definitely be a griffin stand up and FLX fan setup with a 4" inlet hat.
Old May 29, 2012 | 08:55 PM
js2fst's Avatar
So for a daily driver are you. Saying no? Without radiator mods
Old May 30, 2012 | 09:02 AM
LS1RedZ's Avatar
Nah you'll be alright with the f1a on asters bracket, that's what I'm using right now.
Old May 30, 2012 | 09:25 AM
js2fst's Avatar
Aren't the c and r the same size I have all accessories left.
Old May 30, 2012 | 04:32 PM
Inspector12's Avatar
TT-TECH Veteran
I ran the F1R with it. And as far as inlets, I just moved the lower portion of my radiator and condencer forward leaving the upper part in stock location. Trimmed part of the core support and used 4" almuinm 90 and a few other bends to place a Large 4" dry filter on there. Worked great for me 1035rwhp on 93 and meth. That was 17-18lbs of boost on a 427. Good luck.
Old May 30, 2012 | 05:06 PM
UNDER PRESSURE MOD
Now that's something to look forward to. Were you still using an 8-rib pulley?
Old May 30, 2012 | 05:19 PM
35thsscamaro02's Avatar
Wow I would love to see a pic of that inlet setup and radiator adjustments
Old May 30, 2012 | 09:34 PM
TT-TECH Veteran
Yeah 8-rib stock Procharger crank 7.65" and 4.25" blower pulley so it had more in it if I wanted to try for more at the time.
35thsscamaro02 Quote:
Yeah I sold the car and the set up so I don't think I have anything to show you. But I'm sure I posted pictures of everything at one point and time. So if you do some digging under my older posts you'll probably find it etc... Sorry. GL!
Old May 31, 2012 | 12:28 AM
+badss+'s Avatar
Well I'm in process of doing a F1A set up for 15psi with 8 rib stock radiator set up.
Old May 31, 2012 | 07:31 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The F-1A with the stock radiator works out okay, the clearance will just be tight. To the OP, the F-1A can get your car into the 8's in the 1/4. Unless you have a six bolt block/head combo, or a monster cube combo, the F-1A will make all the boost your 4 bolt engine can handle. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
