tips and tricks for lighting a turbo 4.8 car
Old Jun 3, 2012 | 01:26 PM
Fbodyjunkie06's Avatar
Just put a two step on a wot switch under the brake pedal.
Stay on the 2 step the entire time while staging it will build plenty.
I know a guy with a twin turbo caprice who does this and works great.
Still if your timing and fueling aren't where they should it won't matter as it will just hit a wall and no more boost will be made.
Old Jun 3, 2012 | 02:12 PM
LS1NOVA's Avatar
I believe the Ebay GT45 is the same specs as the old Master Power GT45, 69mm compressor, 77mm turbine, 1.05ar. Decent turbo actually.
Old Jun 3, 2012 | 03:09 PM
denmah's Avatar
Moderator
Originally Posted by black98ws6ta
I have hit a ls2 rear mounted c6 with 200 at wot right out of the hole and had the nitrous kit turn off at 10 psi. Worked well on 18'' drag radials.
excellent!
thanks for all the replies guys
denmah's Avatar
Moderator
i know of the MSD and the Lingenfelter box, are there other options?
Old Jun 3, 2012 | 08:20 PM
86lxnotch's Avatar
big thing im worried about with your car is pushing through the brakes if you get it into boost. obv mine is diff but i hooked the 2 step up to my brake and made 10lbs at 3500.....i can actually footbrake it to that point too i believe but havent tried that yet haha. did you talk to frank about it at all yet? you would love a brake in it too i think.
Old Jun 4, 2012 | 12:45 AM
HRHohio's Avatar
Just curious... what gear ratio you running in the rear end?
Old Jun 4, 2012 | 01:44 AM
Synergy and Harlan but they are harder to find as they aren't made anymore.
Old Jun 4, 2012 | 07:15 AM
86lxnotch's Avatar
HRH i believe he has a 2.73 rear gear in it
Old Jun 4, 2012 | 07:26 AM
denmah's Avatar
Moderator
yep. 2.73 and 27x10.5 tire, th400
Old Jun 4, 2012 | 07:52 AM
71 chevy's Avatar
if i were in this position i would get the torque converter restalled to 4k and raise the shift rpm to 7k. cure all your ills in one sweep.
Old Jun 4, 2012 | 10:50 AM
denmah's Avatar
Moderator
converter is always an option for me, but in my experience 4k stalls push too the moon under power.
and they are too loose on the street
Old Jun 4, 2012 | 10:54 AM
  #32
denmah's Avatar
Moderator
i doubt the stock drum rears and stock peanut calipers up front will hold this car while making some boost anyway lol
i upped my shot to 125, waiting for this monsoon the east coast has been getting to stop and make some passes
Old Jun 4, 2012 | 10:55 AM
  #33
71 chevy's Avatar
i think thats because you are rev limiting it to 6500 rpm. imHo. you rev higher and the converter will tighten up.
dont forget, the equivalent piston speed of a 4.8 vs 5.3/6.0 at 6500 is 7200 rpms.
ive never had a loose converter on the street so i dont know anything about that side, sorry.
Old Jun 4, 2012 | 12:21 PM
  #34
Orr89rocz's Avatar
My PTC stalls 4200 under boost now and only 3000 when no boost is on... it drives as tight if not tighter than my 3200 in my 99 daily driver and thats with Th400 and 2.73's compared to 4L60 E and 3.73s. Oh and i shift that PTC at 6K rpm...but now my new setup will go to near 7K if I have to but I'd like it to be done by 6500-6800 so i dont stress things too much.
A converter that stalls at xxxx rpm on boost will not act like your typical xxxx stall on the street that you would have in your n/a car. Off boost you have over half the power missing and thus the converter will not stall. Torque makes it slip/stall.
Old Jun 4, 2012 | 02:32 PM
  #35
468BIGBLOCK's Avatar
Talking i like this thread.
getting this on my list.
Old Jun 4, 2012 | 03:10 PM
  #36
denmah's Avatar
Moderator
when this turbo is lit it hangs at 5500-6000
in a third gear roll on the highway i can push the stall pretty high.
i could try another converter i guess but i am really liking how it drives.
its one way or the other i guess its see what i can do with the nitrous or swap out the converter.
or go into a 4l80e and a lockup converter and get that **** loose as hell for launching. but thats an investment
Old Jun 4, 2012 | 07:33 PM
  #37
86lxnotch's Avatar
5 lug it with sn95 parts..........we will put that bitch in boost
Old Jun 4, 2012 | 11:45 PM
  #38
Zero4488's Avatar
Restricted User
I would definitely loosen the converter up....your leaving a lot on the table...call a couple converter places, tell them your setup, and they should be able to give you what you want....
-Dave
Old Jun 5, 2012 | 07:01 AM
  #39
denmah's Avatar
Moderator
yeah ill probably end up with a circle D or PTC, for now we will see how she does.
i wanna get a aerospace or wilwood kit. i like the 4 lug 10 hole wheels i have
Old Jun 5, 2012 | 08:13 AM
  #40
86lxnotch's Avatar
Put some v8 fox spindles (11" vs 10" u have now) and a turbo coupe rear for disc and you'll be fine
