what do you guys think of this noise
Old Jun 22, 2012 | 08:12 AM
edge04's Avatar
what do you guys torque these down too or do you just snug them up?
Old Oct 8, 2012 | 05:19 PM
edge04's Avatar
Well just had another yella terra rocker go bad. These are their ultra lights. I'm done and replacing them all, guessI have too much power or over revving the motor for these.
So, what to people like here, comp cam magnums, Jessel, TD or??? Big price differnce between the comps and others!
Old Oct 8, 2012 | 08:24 PM
edge04's Avatar
Are stockers 1.7? Would it make any difference to go with a bigger ratio?
Old Oct 8, 2012 | 09:02 PM
Boo"SS"t's Avatar
Unless you're spinning your motor to the moon, I don't really see the need for a shaft mounted rockers, well maybe it's because it's too pricey for my wallet..., but you definately need to stay away from aluminum.
Old Oct 8, 2012 | 09:26 PM
edge04's Avatar
Not sure what the moon is but I go to about 6800. It's a blower cam so pretty mild but pushing around 13lbs and making 625ish to the wheels. I don't see the comp magnums in 1.7.
Old Oct 10, 2012 | 06:23 PM
edge04's Avatar
Anyone know if stock GM rockers will work with my Trick Flow 235 heads or will I need to change guides etc?
Old Oct 10, 2012 | 06:53 PM
denmah's Avatar
Moderator
im doing 654rwhp thru an automatic at 6800rpm on a junkyard 5.3
all stock 200K mile truck junk lol
Old Oct 10, 2012 | 07:52 PM
edge04's Avatar
Well maybe it's something else causing these rockers to go bad like spring pressure. They are the springs that come with the Trick flow 235 heads. Max 650 lift
