Procharger D1SC 34000 rpm impeller speed to low?
From reading various threads on here it seems I need to be around 50000 rpm to make around 8 psi on my set up and right now I'm getting 2 psi at 6000rpm on the the motor. I feel like I'm losing some psi due to my exhaust, cam, and FMIC. I currently have a 6" crank pulley and a 4.25" blower pulley. Im thinking about swapping to a smaller blower pulley to get more boost and want to make sure I'm on the right track and make sure it's not something wrong with my set up
LS1Tech Sponsor
How much boost the blower can produce depends on many variables.
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
If you have a basically stock F Body with headers and exhaust, a D-1SC 6 rib kit with the 6.0" crank pulley and a 4.0 blower pulley will get you around 7 psi, if you're around 500 to 1000 ft in elevation. Whatever aftermarket cam you have is going to lower the boost.
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
A 3.60 pulley should put you close to 8 psi. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
