Holy Crap!! LS1 STS Is Installed
Try looking at the other STS post, or earlier in this one, theres some pictures on here. I dont know how to link sorry.
Charlie.
http://www.ststurbo.com/inc/iview/461?idx=4&p=7237
There you go.
I am just backing off, don't want to get the thread locked.I don't think it'd fit if you have double diamond subframes. These are some of the first pictures I've seen of this setup. Thank you for the link.
Charlie
Charlie
Ya, I forgot about that...Thanks for the heads up.
Time to do a search...When is this guy gonna get it tuuuned? I am going to have my setup done before he is at this rate...
I already got Edit, just need to swap out for better valvesprings, the stockers are fatigued... I don't think they are that cheap, either, starting at $4000. STS + Methanol injection = P1SC kit.
-Geoff
ChevyThunder, what setup are going for? I am personally getting ready to deploy and will be sending my car to a shop that will end up pulling engine, forging internals, and then custom fabbing up a TT setup. A year later, I come back and the car will be 90% complete, just some exterior and interior mods will remain. Thought about this STS kit, for simplistic setup and that extra little oohmp. But, the need for POWER I know will be too great for this kit and my goals.
White Hawk-minus belt replacement for the meth fills. I would still say if they produce the same, the STS would be my choice, lower IATs and I am sure you will need the same add ons for either, injectors, tune, etc... So it comes down to easier install, and maintenance. That and of course preference. No lets see if it produces the power.
Charlie
The STS kit is simple. But I like the traditional turbo under the hood. I've been doing my Turbo Tech install one part at a time. Did the alternator relocation two weeks ago, doing fuel pump and injectors this week. I have to get one more pipe to have everything I need. I intend on doing it in one long day.
For me it's a no brainer, I got plenty of room under the truck to avoid scraping and lots of airflow to keep things cool.
I am currently making around 320rwhp but may drop down to 305-310 when I swap cams to one more turbo oriented.
I'm not gonn acrew around with 2-3psi either. I am popping the 8.1 Marine injectors in (42lbs), the Meth kit, boost controller, GT35 turbo upgrade, and whatever tuning is needed since I already have edit and a good tuner. I am hoping to pull off 10-11lbs of boost but may need a fuel pump. Either way I am pulling for 450+ at the wheels on this 5.3L. It should work really well with my 3k stall since I can launch near full boost in 4wh Hi
I have not been to the track since the new cam and tunning but have shaved off 3 10ths and added 3mph on my G-Timer (compared to my old G-Time results) so with this kit I am pulling for mid 12s.It'll go in before the end of the month and I'll create a new post and let you guys know how it works with dyno AND track #s. To hell with this I "think" it does this garbage
