Good stock crank boosted bearings? Clevite "P" work good?
Trying to find a reasonably priced set of main/rod/cam bearings for my 370 build. Going to use Scat rods, Wiseco pistons, and my 6.0 stock crank.
Are these the generally recommended bearings for ~800rw?
Main: CLEVITE / PERFECT CIRCLE Part # MS2199P TriMetal™
Rod: CLEVITE / PERFECT CIRCLE Part # CB663P TriMetal™
Cam: CLEVITE / PERFECT CIRCLE Part # SH2125S (don't make a "P" in cam bearings)
I will be checking the clearances, but since I am reusing my stock crank that I won't be polishing it (looks perfect as it is), so I plan to use STD bearings.
