Out with the D1SC in goes the F1A
It should touch 800 easy. I made 830rwhp so far with mine with headders that are to small, just about out of fuel on 18psi with the old style F1. The F1A will be quite a bit more efficient...I'd think you should be able to do it on 16/17psi or so. I see that being easy for you man...how about 900? lol
Location: Weatherford Tx 76085 corner of N. Hwy 51 and 150 Green branch Rd.
looking forward in seeing some numbers. What are the cam specs? And how much boost are you wanting to push into it?
#33
yeah i looked recently, and could not find a thread describing the average boost made with an f1-a on an fbody. i am hoping to make 10xx with it. i know it can get you into the 900's but have not really come across any 1k builds with it, but ill keep looking. links appreciated as always.
#36
I might have to take the next step John...car just keeps going further and further down that path anyways. It wouldn't be nearly as impressive as I'll be on a larger cubic inch with a larger blower but it'd be nice to have a couple fast procharged cars that are still street worthy!
#37
OP or blue00zzleeper what is the sound difference from the blower going from a d1sc to a f1 blower? And do you guys think a f1 is too big for a 347? Sorry for the hijak guys...
#38
OK here you go
Work done and tuned by Race Proven Motorsports in Deleware-GREAT PLACE TO GET ANYTHING DONE!
Have a cog drive on my F1A
Nothing fancy
L92 factory heads
LS3 intake
92mm throttle body
9 inch 373 rear
M&H drag radials
close to 900 hp/770 tq
Still drive great on the street.
Nothing fancy
L92 factory heads
LS3 intake
92mm throttle body
9 inch 373 rear
M&H drag radials
#39
Pretty Similar what stall are you using? I am doing a brute speed cam 408, 317 heads ported, 4l80e built, pro yank 3600, meth car weight 4000 lbs. Burkrap sheetmetal rear end 3.89. Properly setup! 85 mm throttlebody and pp intake. I am thinking f-1a or f-1r or f-1 c. And undecided on e-85 Full suspension except a-arms. I might weight on putting k member in until I have a arms.
