lt1 turbo questions
Old Jun 11, 2012 | 09:21 PM
BoostedBird's Avatar
Default lt1 turbo questions
ok here is what i got 97 lt1 trans am
383 all forged internals
ported stock heads
ported throttle body and intake
Svo green top injectors 42# (i think too small)
pacesetter lt headers
rear mount 68mm turbo 5psi boost
lt4 hot cam
the motor was built by the guy i bought the car from with lots of pics and paper work to prove the car has 10.4:1 comp now right after i got it it poped a head gasket at 13psi on stock head bolts. after LOTS of tuning and playing on street tires i have got it in the 12s i am just affraid to take boost up ne more or spray it at that kind of compression..? sound right? should i build a diffrent block with lower compression? if so is there a place i could get a good forged lt1 short block no shops around here mess with lt1 and after the few problems iv had with the car i wish i didnt have it sometimes lol or should i just get bigger injectors for this motor i am new to the lt1 game any info will help
Old Jun 11, 2012 | 10:19 PM
BIG PURPLE's Avatar
You will need to lower your compression and upgrade your fuel system. What type of fuel pump are you running? That's just a start.
Old Jun 11, 2012 | 10:23 PM
Walbro 225
Old Jun 11, 2012 | 10:35 PM
BIG PURPLE's Avatar
Originally Posted by BoostedBird
Walbro 225
I would lower the compression. What fuel do you run? That's not enough pump to support 13 psi of boost.
Old Jun 11, 2012 | 10:39 PM
93 now I bought the water Meth for higher boost numbers. That 225 an water Meth does. Good on my buddy's ls1 turbo car so I thought I was n the clear guess not LOL I don't want the car to b all out drag I do a lot of car shows with it
Old Jun 11, 2012 | 10:47 PM
BIG PURPLE's Avatar
What fuel do you run? I understand you don't want to cross the line from
A street car to an all out race car, if you want to have fun on the street you need to lower the boost.
Old Jun 11, 2012 | 10:49 PM
Pump gas 91 or 93 depending on where I'm at
Old Jun 11, 2012 | 10:55 PM
BIG PURPLE's Avatar
Contact speed Inc or lmr those guys probably can help point you in the right direction.
Old Jun 11, 2012 | 11:02 PM
BIG PURPLE's Avatar
Did you check your water injection to make sure its working properly?
Old Jun 12, 2012 | 05:45 AM
BIG PURPLE's Avatar
You need to also check your timing.
Old Jun 12, 2012 | 06:23 AM
my water inj hasent bn hooked up yet i bought it then was told it needed to be tuned and the nearest place is 2 hrs away
Old Jun 12, 2012 | 07:58 AM
4SFEDZ's Avatar
Do the dual intank Walbro's and atleast 60lb injectors. And yes lower your compresion.
Old Jun 12, 2012 | 09:24 AM
robsquikz28's Avatar
either lower your compression with new pistons or have fun with your setup for this year and do it all next year. I have seen some people including myself run that setup. I had ran 5 gallons of 110 and 5-7 gallons of 93 and upped the boost to 7-8psi. I ran it like that for the entire summer. So it can be done BUT I knew if it blew it up I would be ready.
