GMC Syclone build up
Old Jul 13, 2012 | 02:57 PM
danimal95's Avatar
Originally Posted by GMCsyclone
Thanks for all your help and opinions! I know this conversion will take some time but I think I'll have the same money in doing the 6.0/4L80 instead of the built 4.3 with 700R4.
Motor mount brackets came in yesterday from RPM. Milidon LSX-S10-4WD oil pan came in last week along with the pick up tube.
Yeah the vid of the green Ty coming off the converter smoking all fours was better than sex! Well, maybe for a little while .
thanks guys that was my own personal truck in the vid,15K miles and still going strong,funny thing is i am changing the plugs and wires for the first time this weekend
Old Jul 13, 2012 | 03:15 PM
GMCsyclone's Avatar
I have heard that the tcase from the Ty is a little stronger than the sy tcase. John Waller told me that. He is a big syty guy.
Old Jul 15, 2012 | 02:28 PM
GMCsyclone's Avatar
Aren't they cute!
Attached Thumbnails GMC Syclone build up-syturbo1.jpg   GMC Syclone build up-syturbo2.jpg
Old Aug 8, 2012 | 11:01 AM
sy-nister's Avatar
The ty transfer case has 3 clutches 32 splines vs 2 clutches 27 splines in the sy.
Old Sep 15, 2012 | 10:39 AM
sparkwirez06's Avatar
any progress?
Old Oct 16, 2012 | 10:49 AM
GMCsyclone's Avatar
I have a few projects I am getting done with before I can put all my focus into the Sy. Right now I am designing a Quick spool valved turbo manifold in my FD RX7, but it is almost wrapped up.
The Sy will be a bigger project, gotta get the small ones in and out before tear down begins! I am still collecting all the parts up for the build.
Bryan
Old May 5, 2013 | 02:16 PM
GMCsyclone's Avatar
Started the tear down of the Syclone 2 weeks ago. Don't think its easy working on these things!
Attached Thumbnails GMC Syclone build up-sy01.jpg   GMC Syclone build up-sy02.jpg   GMC Syclone build up-sy03.jpg   GMC Syclone build up-sy04.jpg   GMC Syclone build up-sy05.jpg
Old May 5, 2013 | 02:18 PM
GMCsyclone's Avatar
Engine out!
Attached Thumbnails GMC Syclone build up-gmc1.jpg   GMC Syclone build up-gmc4.jpg
Old May 5, 2013 | 02:28 PM
GMCsyclone's Avatar
On Friday 5/3/13 the 5.3 block bolts to the 700R4 for the engine mounts to be fabricated and installed.
On Saturday 5/4/13 it too 3 hours of midnight madness to get the engine mounts installed. First they are tacked into place. When the engine comes back out, they will also be bolted in to prevent broken motor mount welds down the road.
Attached Thumbnails GMC Syclone build up-sy06.jpg   GMC Syclone build up-sy07.jpg   GMC Syclone build up-sy08.jpg   GMC Syclone build up-sy09.jpg   GMC Syclone build up-sy10.jpg
Old May 5, 2013 | 02:32 PM
GMCsyclone's Avatar
Latter part of Saturday, the desired heads are mocked up!
Trick flow 215's! Boy these things are nice!
Attached Thumbnails GMC Syclone build up-sy12.jpg   GMC Syclone build up-sy13.jpg
Old May 5, 2013 | 03:41 PM
Cajun ELESS-ONE's Avatar
that trucks gonna be badass when its done. Im a sucker for syclones. looking good sir
Old Jun 5, 2013 | 07:44 PM
  #32
GMCsyclone's Avatar
Small update!
Still collecting Camaro parts to gain some clearance. Truck accessories are pushed further forward.
Got the drivers side turbo manifold all tacked up. Still need to place the external wastegate. The steering shaft didn't even have to be removed to do the manifold! You can pull this manifold out and put it in without messing with the stock steering shaft!
Attached Thumbnails GMC Syclone build up-symani1.jpg   GMC Syclone build up-symani2.jpg   GMC Syclone build up-symani3.jpg   GMC Syclone build up-symani4.jpg   GMC Syclone build up-symani5.jpg
Old Jun 6, 2013 | 12:25 PM
  #33
Blackpanther99's Avatar
Ive always wanted a GMC Syclone
Interesting build.
Old Jun 6, 2013 | 11:57 PM
  #34
GMCsyclone's Avatar
Interesting build.
Thanks! If you ever need a small truck, don't hesitate and get one. I love mine. It has been solid reliable! I just got inspired by Speed Inc and decided to do a little updating .
Old Jun 9, 2013 | 09:36 PM
  #35
GMCsyclone's Avatar
Passengerside turbo mounted! Waiting on the corvette, accessories and damper. Hopefully next week I'll have the manifolds all welded up!
Where can I get some information the 5.3 wiring harness? I would like to eliminate all the not needed BS so I can fabricate/simplify a harness to make it fit the truck. The FAST XFI is a big chunk and it doesn't control the coils or transmission. By the time I get all three computers, its over $3K!
Attached Thumbnails GMC Syclone build up-5359_10151401882215855_1719217093_n.jpg   GMC Syclone build up-1002743_10151401884280855_35266779_n.jpg
Old Jun 9, 2013 | 09:39 PM
  #36
427zm's Avatar
Look in' good! Keep the updates Rollin'!
Old Jul 4, 2013 | 01:53 AM
  #37
GMCsyclone's Avatar
I had a lot of stuff going on but managed to do the custom radiator and dual electric fans. Also got in the Wiseco 9-1 compression drop in pistons and their K1 connecting rods.
Next is getting the turbo manifolds all welded up and the external gates mounted.
Attached Thumbnails GMC Syclone build up-rad2.jpg   GMC Syclone build up-rad1.jpg   GMC Syclone build up-rad3.jpg   GMC Syclone build up-pistons.jpg
Old Jul 4, 2013 | 08:56 AM
  #38
Gonoma's Avatar
Use lt1swap.com for your wiring pin outs...nice job so far sometimes I wonder if I should have gone twin turbo on my 97 s10 I'm working on...do you plan to keep ac?
Old Jul 8, 2013 | 01:09 AM
  #39
GMCsyclone's Avatar
Ac is mandatory!
Old Jul 10, 2013 | 11:54 AM
  #40
GMCsyclone's Avatar
LH manifold all welded up. External gate mounted in place.
Attached Thumbnails GMC Syclone build up-symani6.jpg   GMC Syclone build up-symani7.jpg   GMC Syclone build up-symani8.jpg
