Derale 16925 guys?
ok so the instructions said...
Red wire goes to the battery (i have them mounted on the post next to the fuse boxes).
Black wire is ground
Orange wire (w/inline fuse) goes to fan power wire
Green wire is optional for a/c
Yellow wire goes to switched 12v source (as pictured)
so is that the correct spot to plug in the yellow 12v switched or did i misunderstand? i'm not all that familiar with this yet but i think i will know much more after this weekend! is the switched 12v actually a ground? i was just assuming it was power.
yes that's what i'm using Tally is Derale's diagrams which are as follows....
30 Red to Batt (using post by fuse box)
87 Orange to Fan power
86 Yellow to 12V +
85 Black to Ground.
So instead, 85 Black should go to the fuse box in place of the current Yellow wires for the ground/signal source and the Yellow should instead go to the same terminal post along with 30? Do i finally have it right? lol
like i said, i will know a lot more about wiring after this weekend and really, it's about damn time! lol
86 Yellow to 12V +
85 Black to Ground.
that's what i did so it should be all good now. thanks a bunch for the info and patience with the questions Tally! ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
now, do i need a relay for my 5.3amp derale fan on my trans cooler? lol it doesn't say anything about needing one, just a keyed 12v source to the thermostat. wasn't sure if that would draw enough power to require one or not.
#32
just for reference me saying "high speed" means the fan seeing batt/alt voltage ie plain old on
#35
Parallel run both fans on high as each fan would get the 12 - 14V
Series them and they would run 6-7V across each.
In series, you get a voltage drop, in this case, half as there are two fans
P = I V - current is determined by the load, in this case, a Fan wanting ~23A
Im sure that is what you meant (maybe thinking of power sources and voltages)... as you know how three relays are used etc...
