Derale 16925 guys?
I have a SLP manual fan switch but it only turns one fan on and it only operates at 1 speed, no matter if the switch is on high or low.
My tuner want's this fixed before he'll touch it again because he thinks its more than a fan issue. He is using HP tuners so I can't confirm if he's running the fans in series or parallel or even what temps they are triggered. I wish he would use EFI Live, so I can make small changes if needed without having to go back to him, but I guess he can't get it to idle with EFI Live.
Also, what are some reasons for really hot under hood temps? I don't ever remember the stock motor running nearly this hot under the hood, but at the same time, there was never a turbo under the hood. I have everything coated and I wish I would have wrapped them also, but I just think temps are way too hot. Forget about touching anything, its too hot to even hold your hand inside the bay. What are some temps I should be seeing with a temperature gun pointed at the primaries?
This picture is with the old flex-a-lite fans, but it gives you an idea of the layout. The new setup is dual derale pushers in front of the radiator, which is now laid back a little and the tranny cooler is behind the radiator on the passenger side.
