How much power on 92lb injectors on E85 with meth injection?
Im either using the worst dyno on the planet or I think I have something going on in my drive line. I had larger injectors than both of you guys and went lean at 825 rwhp .I would say it might have been runnning out of fuel pump but I have since switched to 2000cc injectors and run more boost with no problems at all. I havent been back on dyno but its feeling pretty strong. The only other think I can think of is maby My injectors werent what they were supposed to be.. I did buy them new and got a flow sheet on them.
Sorry for the semi hijack
What converter are you runing and was it locked?
Hmm What AFR are you guys running your cars at?
