SFI 25.3 Outlaw Street '70 Buick GS Build with 1800hp Twin Turbo 455 LSx
#33
We made a new smooth firewall with recessed pockets for the coil packs
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/adcd1742.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/78362d39.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/caf7d72f.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/f34d5a79.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/cf8314a0.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/6044fbd1.jpg)
Also needed to raise the trans tunnel so we just decided to make a new one with a removable front section......
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/7eb986cb.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/f327ff98.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/9388b2ad.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/b55665f0.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/65c445fd.jpg)
#35
Here is a link to the video of some of the dyno pulls.......
The videos make it look easier than it was - it took almost 100 pulls and 40gals of C16 to get it down. We didn't ring it all the way out as we didn't want to beat it up anymore before it made it into the car. These turbos will max out around 35psi so there is more power to come.
Disregard Tom's comment about it going into an Oldsmobile - it was late at night and he was delirious from getting his *** handed to him by all the "teething" issues that kept popping up.
http://youtu.be/y0s8Oz3QHNI
#36
It's been a while but in case anyone is still interested we are almost done with the fabrication stage of the build........
Seam sealed/primed firewall, Wilwood master cylinder, and steering linkage
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-6.jpg)
DSide downpipe mockup
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-3.jpg)
PSide downpipe mockup
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-2.jpg)
3" to 3.5" transition from turbo (for future upgrades)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-4.jpg)
Transition from round to oval tubing
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-7.jpg)
Borla mufflers
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-12.jpg)
3.5" tubing over the rear (this was a major pain but it clears)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-9.jpg)
Overall the exhaust is tucked between the cage and the body - it won't even be visible unless you roll under the car
Borla mufflers
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-13.jpg)
#37
Few more misc progress pics.....
Heat exchanger mounted under trunk floor for liquid intercooler....
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file.jpg)
Tubular radiator mount
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-1.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-14.jpg)
Bell crank throttle linkage - this took some heavy duty thinking to figure out - Alec is smarter than me.......what can I say?
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-11.jpg)
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-10.jpg)
Bulkhead for AC lines thru firewall
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-8.jpg)
Removable trans crossmember
![](http://i1173.photobucket.com/albums/r600/TwinTurboGSx/Fabrication/file-5.jpg)
It's starting to take shape. Hats off to my man Alec - the guru of fabrication!
