Question about oil return on rear mount turbos
![Red face](https://ls1tech.com/forums/images/icons/icon11.gif)
I am mounting my turbos on my ****** jeep rite behind the oil pan down low so my question is do i have to have a oil return pump or will the pressure from the incoming oil push the oil back to the pan?
the rule is as long as the turbo is above the oil level in the pan you can run it without a pump as long as the oil return hose is not going uphill. if you are lower than the oil or have to go upward you have to have a pump
If you can't run a drain at a gentle slope to the pan (above where the oil level is), then you need a scavenge pump to keep the oil from backing up.
