need advice on CID on lsx turbo motor
Trying to get an idea of the perfect CID for my turbo motor here is a few goals for the car.
Street/ strip car 1100 hp goal
Fuel is goin to be e 85 with an intercooler
4l80e transmission
Will be using an 88mm turbo
Lsx block
Ls7 heads
Now I have heard a few different opinions as 370,390,400,410 CID let me kno what you guys have or reccomend thanks guys
4l80e transmission
Lsx block
Ls7 heads
Since you're going LSx block, should try to get as many cubes as possible without sacrificing the effienciency of the combo. 427ci seems to be what most go with, thats the ci mine is also.
Good question, LME and a few others are having good results with a large bore short stroke configuration. LME builds a 388" motor I think its a 4.125 bore X 3.622 stroke. I personally would go this route only because when you go 427+ it takes a huge exhaust side of the turbo (turbine wheel & housing) to keep from having big backpressure issues.
I personally don't think a off the shelf 88mm turbo is going to flow enough exhaust for a LS7 head on a 427.
