Dissapointing Dyno Numbers. Any Ideas?
There is an Ultraflo muffler on Summitracing that is around $80 and is one of the highest flowing and quietest mufflers out. Ditch the Flowmonster. Chambered mufflers are bad news on turbo cars.
You can also run an electric cutout!
I'm wondering how U R getting 103* IAT's with the filter being blown full of hot air from the rad. [And, the cold side laying on the turbine housing.]
As others have commented....Timing is low for that amt of boost.
I also see you have 72# of fuel psi. Assuming you have a boost referenced reg, base fp is 58[?]. With 7# boost the fp should be 65, not 72. If this is an accurate "assumption", I'd try to lower the fp to get the base + boost accurate, and let the AFR come up to 11.7-11.8.
I'd also check back psi in the exh, B4 and after you disconnect the Blowmaster...
As for the tires. I've seen waaay too many slick blow outs on the dyno, to use them for that purpose...
I had a 3.5" race flowmaster on mine and it kept building pressure and blowing the pipes apart at the joints...lol. Peice of junk. I went with the 3.5" ultraflow and it rocks.
single 3" should be fine. wouldn't hurt to take a look at your exhaust pressure both before the turbo and after the turbo.
I'm not a tuner, but 11 degrees seems pretty low. rule of thumb i've always gone by is 18lbs/18 degrees on pump (usually associate that with imports), but i can't imagine thats too far off with an lsx engine.
11deg/11lbs is a good tune up on 91 w/o meth. With some room to add more boost or timng.
Clutch slipping/poor valvesprings/exhaust are good things to look at first.
I agree with everyone about the timing and flowmaster but IMO something else seems wrong even with more timing & open downpipe the car will be around 400rwhp with this setup six speed trans I'd expect 470-500rwhp on 11psi maybe slightly more..
Is that 2.5 downpipe?
Awesome looking setup man good luck finding the issues.
I rechecked compression today, it's 180 on every hole. How would I know if the cam is installed wrong other than pulling it all apart and looking at the dots again? Compression is good so I'm guessing the cam is in right?
I scanned for codes and got a PO332 and PO327, knock sensor bank 1 and 2 low input. This means timing is retarded under load, right? The tuner said he was doing something with the knock sensors, maybe he didn't? Or did something wrong?
I am building a cutout, not a fancy electric one just something that looks 1957 and dumps under the car. I am certain the IAC's were at 103* but I doubt they are that low with the hood closed going down the road. Thanks for all your input!
