No Low End Power With Boost - Time Slip Pic...
11 Second Truck Club
Your lack of bottom end is because you are now entering the part of the timing table that has very low numbers possibly even negative numbers in the lower RPM ranges. Put a 3600 stall in it and crank up the boost!!
