Procharger, TT, or Single Turbo
Old Jun 30, 2012 | 10:11 PM
+badss+'s Avatar
Good luck on that, but ill tell you it looks nice. and from what others say it works.
Old Jun 30, 2012 | 10:50 PM
Jadedbird's Avatar
I've seen several on forums used . And Ive seen a few on eBay and Craigslist...
I have a shopping problem
Old Jul 1, 2012 | 12:57 PM
02gangsta/ss's Avatar
Originally Posted by Jadedbird
12 on a stock Motor? For how long?
its been over a year ....its not a daily driver though but alot of it is in the tune i am lucky to have don at slowhawk close by my area and have had zero issues i do run 100 % meth though with this setup
With no belt slip on 8 rib? Just get the aster bracket so when you do upgrade to f1 size it will help on higher boost.
i know i dont have any belt slip ...that doesnt mean down the road i wont ...i do know that i have the 8 rib setup and i did have to get a certain special belt dont know if that helped but no slip for me
Old Jul 1, 2012 | 01:03 PM
http://youtu.be/q3IkF9Zz7bU here is the latest video i have from this year
Old Jul 1, 2012 | 02:14 PM
I8UR4RD's Avatar
made 600/577 @ 9lbs with bolt ons and a cam on my a4 ws6 with ls1. i am working on the aster bracket now and trans now. its an easy kit, hassle free as long as you get the aster. its expensive, and even if you dont know you have belt slip you most likely do. youll know when boost kicks up after adding it on. if your running 12lbs now..hell you might add 1 or 2 more adding the bracket.
