twins with short down pipes. WB02 setups?
Old Jul 8, 2012 | 02:36 PM
WheelsUp84z's Avatar
Default twins with short down pipes. WB02 setups?
The way I want to run my twin setup is with the down pipes coming out of the fender like how I have my single set up right now. This will leave me with 12-18" of downpipe at most from each turbo. My question is, is that enough pipe to put wideband o2s on and get accurate readings? I'm looking at the Fast dual sensor setup right now, since it seems to be about on par cost wise as 2 individual innovatives. Any thoughts on this?
Old Jul 8, 2012 | 03:25 PM
SKINNY69's Avatar
I've always heard that anywhere past 12" is fine. Even if you place them a 2" from the end of the pipe, no outside air is going to interfere with the readings.
Old Jul 8, 2012 | 04:47 PM
MUSTANGBRKR02's Avatar
I don't think this is accurate.
Old Jul 8, 2012 | 05:09 PM
denmah's Avatar
Moderator
ive run turbo setups with the WB very close to the turbo and dumped and not had any problems.
you could always put it on the pressurized side even though its bad for them theyll last long enough i would say.
Old Jul 10, 2012 | 10:07 AM
123quattro's Avatar
I would put them right at the outlet of the turbo. If you put them near the end of the pipe like Skinny69 suggested you will certainly get erroneous (lean) readings.
Old Jul 11, 2012 | 07:05 AM
SKINNY69's Avatar
Ok... I was exaggerating just a little. Have you guys not witnessed tuning shops clip a WB onto the tailpipe and tune like that?
I'm just saying that a 12" downpipe provides plenty of room to mount a WB.
Old Jul 11, 2012 | 10:19 PM
86lxnotch's Avatar
yes but the sampler goes a good 12'' into the pipe and still isnt the rec. way to do it.
i would go about 6'' off the turbo and put it there. thats roughly were mine is at and has been ok so far
Old Jul 12, 2012 | 12:53 AM
itsslow98's Avatar
Mine is 8 inches after the turbo outlet.
Old Jul 12, 2012 | 04:46 AM
sounds good that'll put me to about 1/2 way in between the strut towers so I can just run the wires up the side.
Old Jul 12, 2012 | 10:22 AM
123quattro's Avatar
Yeah, I've seen that. I have a wideband permanently mounted in my my car after the long tubes. When we dynoed it we compared with the shops clip on tailpipe reading. Under heavy load they both matched up. Light load mine was showing stoich and theirs was reading 17:1.
Old Jul 12, 2012 | 10:57 AM
95bowtie's Avatar
If you look up my down pipe you can see the wideband sensor actually its maybe a foot and a half from the exit and wot/cruising it shows accurate readings. Part throttle I get steady readings no crazy lean readings coming up ever.
