Any Procharger guys have main belt problems?
Old 07-19-2012, 06:19 PM
whiteboycntdnce's Avatar
Default Any Procharger guys have main belt problems?
I'm not real sure if this has anything to do with the fact that the car is supercharged or not, but figured I'd ask here anyway.
My main belt keeps trying to walk off at the crank pulley... I'm running an ATI under driven crank pulley and a stock auto tensioner, however I do have a different pulley on the tensioner (taller sidewalls). It only walks 1 rib off and seems to do it at higher rpms. Any ideas? Do I need a manual tensioner?
If anyone else has had this problem, please chime in.
Old 07-19-2012, 06:23 PM
01boydws6's Avatar
LS1Tech 10 Year
Sounds like pulley Mia alignment
Old 07-19-2012, 07:05 PM
kvelasco1's Avatar
I have a procharger d1sc on my camaro and kept throwing off my main belt at high rpm. I put a manual tensioner on it and havent had a problem again. I had no misalignment issues with any pullies, belt was and is nice and straight.
Old 07-19-2012, 09:01 PM
jjcamaro02's Avatar
LS1Tech 10 Year
Same thing here.
Old 07-19-2012, 10:13 PM
blue00ZZleeper's Avatar
I used to throw mine all the time. It actually wiped out the blower belt before as well. I put a speed Inc manual tensioner on it and didn't have a problem with it again. Throw a manual tensioner, put a decent amount of tension on it and you'll be fine. I honestly think it has something to do with the harmonics and how much the belt is able to deflect. I tried putting a new spring adjust tensioner on it and it helped for a bit but did it again...with the manual it hasn't done it again yet.
Old 07-20-2012, 10:32 AM
AFASTYZFR1's Avatar
Need some help guys, can't get this belt right but have tried shimming the auto tensioner both ways.
I don't see why a manual tensioner would help....I have this exact same set up on my car and can spin to 7200rpms with no problem but I have a stock balancer.
I'm going to grind material off the auto tensioner and try to bring it closer in to hold belt back
Here is a video:
Old 07-20-2012, 11:01 AM
josepy121380's Avatar
Mine did the same when I put the blower on. I put a manual tensioner on. Has not happened since for 3 years now.
Old 07-20-2012, 12:39 PM
Hi-Po's Avatar
Car didn't have a blower, but my TA would throw the main belt at high RPM also. Put a Katech manual tensioner on it and haven't had a single problem since.
Old 07-20-2012, 12:46 PM
ramairetransam's Avatar
LS1Tech 10 Year
mine was jumping two teeth constantly , i went and bought a new one from napa or advance , it came with the pulley too , put that on and havent had one pro0blem , i used to be able to push the old tensioner over and move it , the new one is like a brick wall . 55k on my stocker and it was shot .
Old 07-20-2012, 01:11 PM
This is a brand new tensioner from napa... Still having the same problem. Thinking about just going with a manual.
Old 07-20-2012, 01:19 PM
LS1Tech 10 Year
If you have a new tensioner and at that low rpms it has to be an alignment issue. Do you have a
Straight edge to put on it. Something is off.
Old 07-22-2012, 11:25 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
I have been having this issue as well since putting my motor back together. It jumps two ribs on the tensioner and powersteering pulley but stays on the alternator and crank pulley without moving. I can't see how the pulley could be the issue, but I'll try reversing the pulley on the tensioner to see if that could help.
What's this 'buick pulley' people talk about?
Old 07-22-2012, 11:59 AM
stevieturbo's Avatar
Manual Katech tensioner on my accessory belt, no issues here.
Mine did walk when I had the auto tensioner, but I just assumed it was f**ked. Running the manual ever since with zero problems.
Old 07-22-2012, 12:38 PM
AFASTYZFR1's Avatar
Just threw a manual tensioner on and have the same problem
Old 07-22-2012, 01:31 PM
Hmmm. Belt alignment must be off pretty bad then? That's odd. I know mine is off just a touch and the manual tensioner with quite a bit of tension on it took care of the problem.
Old 07-22-2012, 02:13 PM
conan's Avatar
It looks like the way the belt is walking either the crank pulley is to deep in the motor or the belt grooves are machined wrong.
I'm running a ATI super damper with the stock spring tensioner, never had any problems with the main belt walking on me.
Old 07-22-2012, 02:20 PM
5w20's Avatar
time to use the gates laser alignment tool
Old 07-22-2012, 03:04 PM
Simple straight edge is cheap and I'd say more effective.
Old 07-22-2012, 05:45 PM
UNDER PRESSURE MOD
I think my issue is the age of my belt for one. It's the original belt, although it was run on the car for a good 6-7 of the last 12 years the car was running as I had an underdrive pulley on the car. I don't think the crank pulley is too deep or else I'd be having issues with the Procharger belt.
It just sucks that you have to remove the head unit to replace the main belt.
Old 07-22-2012, 05:51 PM
How much tension are you putting on it, and what condition is the belt in ?
Try a new belt and apply a decent amount of tension. IMO the reason I had issues with the auto tensioner was down to the fact it was just too weak.
Run it for a while then re-tension the belt, as a new belt will stretch a little.
And following on from another thread....it's worth fitting an LS2 pump with the pulley pulled off a few mm.
Creates so much extra space in there !
Quick Reply: Any Procharger guys have main belt problems?
